Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-10-2008, 10:49 PM   #1 (permalink)
KompressorMonkey's Avatar
Date registered: Mar 2008
Vehicle: 2k2 c230 kompressor coupe
Send a message via AIM to KompressorMonkey
need some serious advice help the needy
im new to the forum and today what had happen was....long story short my friends dad played a prank on him drove his car away in front of him while his mom was parking the car "mom had a panic attack and backed into my grill" so cosmetically it didnt look too serious just a bent star now to the serious part of this im not shure if my radiator is cracked or something, i dont see any leaks of fluid but the heat of the engine went up for me what it looked like wasnt normal any ideas why its alittle above normal it also fluctuates higher and lower and i was stationary the whole time. i washed the car before the incident happend, it was low 70s degrees im in nyc
KompressorMonkey is offline   Reply With Quote
Old 04-10-2008, 10:59 PM   #2 (permalink)
also would any of you have any idea if i had a cracked radiotor would it give me a CEL?
Old 04-11-2008, 03:13 AM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
that temp is normal.
Streetglower is offline   Reply With Quote
Old 04-11-2008, 05:44 AM   #4 (permalink)
Eesjunin's Avatar
Date registered: Apr 2007
Vehicle: 2002 Mercedes C320
The temp seems a bit high, i dont think mine goes over 80 at any given time...well maybe when its 100+F outside...Just a comment, not sure on the rest of questions
Custom painted front lense covers and grill; Tein Lowering springs; Custom Flowmaster dual exhaust; K&N filters; de-badged; Euro style rear window spoiler; AMG trunk lip
Riegers body kit;
Eesjunin is offline   Reply With Quote
Old 04-11-2008, 06:52 AM   #5 (permalink)
Date registered: Oct 2006
Vehicle: '06 C55, '04 Audi TT 3.2 Cpe, '53 MG TD, '48 Willys Jeepster, '35 Ford 5w dlx Cpe
I cracked a radiator a couple months ago when I hit a bobcat (the animal kind). Temperature never budged from normal for the two hours that I drove it on the freeway. The first I knew that it was leaking was when the low coolant warning came on.
lkfoster is offline   Reply With Quote
Old 04-11-2008, 11:38 AM   #6 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
check for coolant leak first. temp is aways going to be high for forced induction cars. mine hovers around 90deg daily.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 04-11-2008, 02:16 PM   #7 (permalink)
Vehicle: 2003 C240 4Matic
The temperature looks about average. The temperature fluctuation is normal, too. As the temp goes up, it causes the fans to kick in, and as the fans draw air through the rad, the temp goes down.
Whosdis is offline   Reply With Quote
Old 04-11-2008, 04:06 PM   #8 (permalink)
Black04C230's Avatar
Vehicle: 2004.5 C230 Kompressor
My temp is usually at 80 almost always, so I would say it might be a bit high. If your grill only had a bent star, I would find it hard to believe that this accident caused any harm to the radiator though.
2004.5 C230 Kompressor.
C55 Lip Spoiler, Roof Spoiler, 3 Fin Grill, Flat Emblem, Clear Corners, Smoked Tail Lights, Smoked Third Brake Light, and Window Tints.
Black04C230 is offline   Reply With Quote
Old 04-11-2008, 07:26 PM   #9 (permalink)
virgoe's Avatar
Date registered: Feb 2007
Vehicle: C280 2008, C180 Kompressor 2006 (SOLD), C230 Kompressor 1999, 190E 1986 (SOLD), 240D 1982 (SOLD).
Send a message via MSN to virgoe
i had a similar problem with my 230k 99, but it seems that MB cars work at very high temperatures .
virgoe is offline   Reply With Quote
OT: Lawyer in limo looks after the needy oztds R170 SLK Class 2 04-06-2008 05:38 AM
Advice after advice on radio,HID(xenon) here it is pinoycanuck W210 E-Class 5 06-24-2007 04:08 PM
HELP - buying advice... and then running advice 72 280SE 3.5 skills2paythebills Vintage Mercedes-Benz 1 10-17-2005 02:58 PM
Some advice please Jillian80 W126 S,SE,SEC,SEL,SD,SDL Class 15 06-09-2005 08:47 AM
need advice coke W203 C-Class 2 12-15-2003 03:24 AM
