Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-10-2008, 11:32 AM   #1 (permalink)
Date registered: Oct 2007
Question about code P0010
I have a 03 230 Sport Coupe, with the misfire issues. 2 & 4 fail to fire properly on certain occasions. My situation is different from others in the fact that 99% of the time it only happens when the vehicle approaches redline or in the redline. Here resently about 3times a week. Went to Autozone for download, kicked out code P0010, which says its the A position camshaft actuator electrical position . Is this referring to the cams shaft sensor. This problem has occured since I bought the vehicle in 2004 w/ 20000 miles on it. Merc. has since replace the computer (2), the top end of the motor, all coil packs and the latest service campaign for the S/C hose.
Now that it is no longer under warranty, I tend to do my own maint. Anybody else out there with any suggestions. Thanks in advance
riceburnergst is offline   Reply With Quote
Resetting FSS question (error code question) TheOgre W163 M-Class 7 04-25-2008 02:37 PM
VIn code question Dukming W126 S,SE,SEC,SEL,SD,SDL Class 3 04-04-2007 07:23 AM
Paint code question 420 SE W126 S,SE,SEC,SEL,SD,SDL Class 2 02-02-2006 07:24 PM
Question about paint code. Alex Guess G-Class 2 05-09-2004 09:01 AM
Radio code question. Syd R170 SLK Class 2 04-06-2004 12:14 AM
