Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-10-2008, 10:45 AM   #1 (permalink)
GonzBenz9910's Avatar
Date registered: Mar 2008
Vehicle: 2004 C230 Kompressor
Send a message via MSN to GonzBenz9910
Question audio system advice
I have had a couple of cars in the past that I hooked up with audio components. I haven't for a long time. Now that I have my first mercedes I think it's about time to do it again. I have done some research and pretty much know what I want. I am looking at infinity kappa speakers for the doors with a 4 channel amp by infinity also. I am not sure if I am going with a sub or not (give me your opinion on that, I don't want to drown in bass). The head unit is where I run into trouble. I found a sweet kenwood double din that I like and an eclipse head unit as well. First does anyone have any advice or changes they think I should make? And second if anyone has done their own install. How hard is it on a c230? Thanks.
GonzBenz9910 is offline   Reply With Quote
Old 04-10-2008, 06:00 PM   #2 (permalink)
Date registered: Apr 2008
Vehicle: 2005 C230 SS
I would contact Steve at mbenznl.com, he can hook you up with a nav unit/bose system. Personally, I think you can get a sweet stock upgrade by that approach.
steveaustin is offline   Reply With Quote
Old 04-13-2008, 10:05 PM   #3 (permalink)
Thanks for the recommendation I am definitely going to check that out. I have heard some great things about the Bose system. Do you have one?
Old 04-13-2008, 10:42 PM   #4 (permalink)
I have a 2005 with the Harman-Kardon Entertainmet Package. I just think keeping with stock parts will be a cleaner looking approach. The cd-based navs are cheaper and I'm pretty sure you can upgrade to a nice stock bose system. I've heard the bose are better than the H/Ks. I've had my amp replaced under warranty and some other issues with software updates. You can reach steve at his website mbenznl.com. Keep us posted on what you do.
Old 04-14-2008, 08:17 AM   #5 (permalink)
Date registered: Aug 2007
Vehicle: C320 4matic
Send a message via AIM to Tri-Star
Is this for a european command? I currently have command/bose but the european version allows dvd in motion.
The thought of adding a subwoofer crossed my mind but I decided not to touch the system and use the money upgrading elsewhere.
Tri-Star is offline   Reply With Quote
Old 04-14-2008, 10:22 PM   #6 (permalink)
I contacted Steve. They responded and asked where I was located. I am just waiting for the response. I definitely am interested in the system. Is this something I can most likely install myself?
AUDIO SYSTEM....HELP PLEASE!!!!! MercBenzito W202 C-Class 2 11-12-2007 04:26 PM
audio system help snakoiler W208 CLK Class 3 10-05-2007 03:26 PM
UK - Digital Audio Broadcast audio system beverage R171 SLK Class 1 01-20-2005 10:12 AM
Audio 20 System Duo-Art R171 SLK Class 7 07-21-2004 01:44 PM
any suggestion on what kind of audio system should i use to replace the stock audio? 9JR W208 CLK Class 3 10-17-2001 07:48 PM
