Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 03-05-2008, 10:20 AM   #1 (permalink)
Date registered: Jun 2007
Vehicle: 2002 C230k
Send a message via Yahoo to dply27
Ill Fitting Gas Cap
Hey again,
Another problem that I am having with my 2002 c230k is the gas cap seems to decide when it is gonna fit and when its going to turn all incredible hulk and be too big to get in. Ha. Also sometimes when I'm driving my screen goes bright red and tells me gas cap is off and sure enough when I go check the gas cap it has come loose while I was driving.
Any help with this one?
I've had the car for a long time and I love almost everything about it but all of a sudden it is acting really weird on me.
dply27 is offline   Reply With Quote
Old 03-06-2008, 02:28 PM   #2 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
Originally Posted by dply27 View Post
Hey again,
VERY CAREFULLY check your Gas Cap and see if someone CROSS THREADED your Gas Cap.
It should fit on 1-2-3 without all that monkeying around your doing.
If Defective order a new one through Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips
If the cap is left off; a Warning Light will come on.
Nice little feature eh?
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Old 03-06-2008, 03:06 PM   #3 (permalink)
Vehicle: 2002 C230k
Thanks for the hint I looked at checker and they are 39.99 for a genaric piece of crap and on that site its only 20.
Old 03-19-2008, 04:28 PM   #4 (permalink)
Date registered: Mar 2008
Vehicle: 2003 C230K Sports Coupe
All you have to do is adjust the inside of the gas cap...
Javier Castro is offline   Reply With Quote
Old 03-20-2008, 02:09 PM   #5 (permalink)
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
Yes there is nothing wrong with your cap. Take it off and examine it good. There should be two metal tabs and if you push up on both of those at the same time you can actually rotate the plastic center part. This should re-align your gas cap. It not really "easy" as there is some force on those tabs but you should be able to do this yourself without any tools.
kyle21nluvnit is offline   Reply With Quote
Old 03-20-2008, 05:44 PM   #6 (permalink)
MJ50's Avatar
Date registered: Nov 2003
Vehicle: C240 & ML350
Send a message via ICQ to MJ50 Send a message via AIM to MJ50 Send a message via MSN to MJ50 Send a message via Yahoo to MJ50
if u get error msg, then u need a new gas cap....
the old one is prolly not closing securely....
2003 C240 done modding
2004 E55 MBenzNL, RENNtech pulley, ECU, VRP split cooling
2004 ML350 modded & sold
MJ50 is offline   Reply With Quote
Old 05-14-2008, 12:29 PM   #7 (permalink)
Vehicle: 2002 C230k
Thanks for all the help everyone. I bought a new one before I saw all the replies and it fits perfectly but now the CEL won't reset. Is there a way to manually reset it or do I need to borrow one of those code things?
Gas Cap? johnamoss W210 E-Class 1 12-12-2007 05:41 PM
smell gas in and out ... gas tank cap? allerton W126 S,SE,SEC,SEL,SD,SDL Class 12 07-10-2006 05:55 AM
Fuel filler cap (Gas cap) types26/36/74 R170 SLK Class 2 09-28-2005 01:46 PM
SL 320 gas cap, lots of pressure and gas on my shirt :-( e300d R129 SL Class 2 07-21-2004 08:36 AM
gas cap donsig G-Class 2 06-20-2003 12:09 PM
