Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 03-03-2008, 03:52 PM   #1 (permalink)
Date registered: Feb 2008
Auto Transmission Oil Pan Leaks
Changed the engine oil and filter on my 2004 C230K this weekend (thanks to all the DIY posts) and everything looked really clean except that the transmission oil pan seems to be leaking, drips coming off the bolt heads and none of the bolts were loose. The gasket which is like a 1/4 inch thick also seemed soaked. Is this very typical? People who are changing the trans fluid themselves are you putting any RTV sealer on the replacement gasket?
schilder71 is offline   Reply With Quote
Old 03-03-2008, 05:07 PM   #2 (permalink)
Date registered: Mar 2007
trans pan or trans connector? the 722.6 trans have leaky connector.
Motioneffects is offline   Reply With Quote
Old 03-03-2008, 09:16 PM   #3 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
This is actually a common problem for MB, they leak at the seals by the electrical connection. I haven't heard of it hapening to any 2004's yet so I haven't looked but the part is cheap, $8 and I'm doing it to my kid's SLK on Friday.
Old 03-03-2008, 09:41 PM   #4 (permalink)
utiadam's Avatar
Date registered: Mar 2008
Send a message via AIM to utiadam Send a message via MSN to utiadam Send a message via Yahoo to utiadam
It is a common problem that we see at the dealer. We usually just replace the Trans. Connector. If the car is getting a flush and filter we remove the pan and put a new gasket. The pan is held in place with aluminum bolts that only get used 1 time. They are torqued to 4Nm, which isn't very much so be careful not to break any of them.
utiadam is offline   Reply With Quote
Old 03-04-2008, 08:31 AM   #5 (permalink)
Hmm, OK, I didn't look hard enough to notice a connector. So can I just replace the connector by itself or do I have to replace the connector along with the oil pan gasket?
Thanks In Advance,
Dave.
Old 03-04-2008, 03:36 PM   #6 (permalink)
2004 C240 White's Avatar
Date registered: Jul 2007
I have a 2004 c240 and I have had the same problem with just 1 bolt. It would leak from the center passenger side bolt (on the pan) and it is a maddening problem. What do you guys mean by trans connector?
"When the people fear their government, there is tyranny; When the government fears the people, there is liberty."- Thomas Jefferson
"Among the many misdeeds of the British rule in India, history will look upon the Act depriving a whole nation of arms, as the blackest." - Mahatma Gandhi
2004 C240 White is offline   Reply With Quote
Old 03-04-2008, 05:38 PM   #7 (permalink)
Date registered: Dec 2004
Vehicle: 400E, 500E, 560SEC, C240
I beg to differ on the one time use pan bolts? The bolts appeared to be the same steel bolts that I have seen on other mercs?? mine were reused w/out any issues? I have changed my trans fluid twice in 115K miles.
Redwood
400E 4.2
500E 5.0
560SEC 5.5
C240 2.6
redwood is offline   Reply With Quote
Old 03-05-2008, 08:29 AM   #8 (permalink)
Try thoroughly cleaning the bolt and bolt hole and put a light coating of RTV sealant on the bolt threads and torque per specs.
Old 03-05-2008, 03:51 PM   #9 (permalink)
they are stretch bolts. you can reuse them, but benz do not recommend it.
Old 03-06-2008, 02:25 PM   #10 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
Sounds to me like nothing more than an improper Gasket Installation.
Recommend you Drop the Pan again, Saving the Fluid
Make sure the Gasket is not PINCHED or is laying cock-eyed.
When reinstalling the Bolts use Thread Lock and at First Hand Tighten them
Then Tighten them down.
Wipe everything down real clean. Not a lick of Oil anywhere.
This is important so if you do have a Leak, you will know it instantly and where it
comes from.
I did not use any RTV Sealant. The Gasket was Plenty Fat Enough and lightly
draped over the side of the Pan.
I did a DIY on this in the W202 Section replete with pictures.
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Auto Gearbox Transmission 722.6 oil Banhoff W202 C-Class 2 02-20-2007 11:13 PM
Auto Transmission oil levels Malcolm_g R170 SLK Class 3 10-12-2006 11:13 PM
auto transmission fluid leak - pan area... Jez280CE W123 E,CE,D,CD,TD,TE Class 5 06-19-2006 08:39 PM
Sagging hose beside transmission oil pan? KTwo W124 E,CE,D,TD Class 3 04-08-2006 08:32 PM
oil pan / drivetrain leaks aggragated G-Class 8 09-23-2004 09:50 PM
