Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 03-03-2008, 01:39 PM   #1 (permalink)
Date registered: Nov 2007
Vehicle: 02' c230 Komp Coupe
Noise from Engine/Transmission in my c230
Hi I am new here to the forum and I apologize if someone asked the question before. I searched and looked all over the place and I didn't find the same problem, so please bear with me
I have a 02 c230 Komp coupe with less than 60k miles on it, and I had a B-service last Feb with flushing transmission fluid. I seemed to have a repeating tickling noise problem either from the engine or the transmission (I couldn't tell). The frequency of the repeating tickling goes up when speeding up. Also it pops out randomly, sometimes in half an hour after I start the car or over an hour. I do know that when I stop more frequently or changing from D to R/P more often, the problem comes out sooner. The noise seems to come from under the shift stick, but sometimes I feel it comes from behind the AC. Please help and any information is appreciated!
Thanks!
josephile is offline   Reply With Quote
Old 03-03-2008, 09:46 PM   #2 (permalink)
Landshark_dg's Avatar
Date registered: Apr 2006
Vehicle: 2001 C320
Common problem. It is the insulation that surrounds your driveshaft. As it heats up, it exands (which is why you hear it after driving for a while). You can trim the insulation yourself or take it to your dealer and have them add a support 'cage' that holds up the insulation. I think it cost me $150 to do it.
Annoying as hell but nothing to worry about in terms of mechanical problems...
Landshark_dg is offline   Reply With Quote
Old 03-04-2008, 01:13 PM   #3 (permalink)
Thanks a lot! It's good to know that there is nothing wrong mechanically.
Regular C230 engine vs C230 "kompressor" Benzonline W202 C-Class 7 11-18-2008 10:46 AM
1997 C230 Noise from the dash????? mpelchen W202 C-Class 2 12-02-2007 12:21 PM
2006 C230 Ticking Noise charris W203 C-Class 2 10-30-2005 06:18 PM
CLICKING NOISE WHEN I TURN AC ON 97 C230 !!!!!!!!!! nubiansfinest W202 C-Class 4 09-26-2005 04:59 AM
C230 RF tire / suspension noise MR.MB W202 C-Class 0 10-24-2004 06:56 PM
