Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 02-29-2008, 07:03 AM   #1 (permalink)
Date registered: Oct 2007
Question Felling vibration in C230K
Hello
I own a 2005 C230 Kompressor (sedan). I purchased the car a couple of months ago with only 10.000 miles. My problem is that I feel a kind of little vibration when I stop on a red light and the shift gear is on Drive, especially if the A/C is on. i don''t feel that when the shift gear is on P. Than when i move the shift on N the little vibration is gone.
Can anyone tell me if this is normal or there is something wrong with my car ?:
B2BC230 is offline   Reply With Quote
Old 02-29-2008, 09:39 AM   #2 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
It's probably one of the typical engine problems that car has. Search the forum for details but here's the 4 most common;
1. vacuum line under the intake is rotten and the leak is causing your idle roughness
2. exhaust valves gets dirty causing a leak causing a rough idle
3. cam sensors leak oil into wiring harness destroying the O2 sensors
4. MAF sensors get dirty, needs cleaning, can cause a rough idle
MB discontinued this motor after only 3 years because of problems.
Old 02-29-2008, 06:31 PM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
there is an issue with the belt tensioners failing on the kompressor engines. the giveaway is when you put the car from park to drive and the car starts vibrating heavily in the engine bay.
Streetglower is offline   Reply With Quote
New C230K Danno_KC W203 C-Class 6 12-29-2007 06:21 PM
Anyone try to fit a 05 c230k front bumper on a 04 c230k? ohhmickaay W203 C-Class 1 11-27-2007 05:43 AM
c230k engine vibration zack W202 C-Class 1 03-22-2006 06:24 PM
99 c230K 2.3L sportsbone00 W202 C-Class 1 07-20-2005 12:03 PM
c230k geoff2005 W203 C-Class 4 05-09-2005 06:52 PM
