Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 02-24-2008, 10:53 AM   #1 (permalink)
Date registered: Nov 2007
Question 2007 C230 engine
Hi,
I'm looking into buying a 2007 C230 which has the V6 engine. Does anyone know how the V6 performs compared to the kompressor engine in terms of reliability and maintenance specifically and also performance, etc. I have heard that many people prefer the kompressor engine to the V6, why is that?
Thanks.
bondock is offline   Reply With Quote
Old 02-24-2008, 11:47 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
in terms of reliability, the new v6 would be a better choice. the 272 engine hasnt been out that long, only for a few years but so far i havent seen any major issues with it. now the kompressor engine is a 4 cylinder 271 engine. they are known for misfire issue related to leaking valves, worn valve springs, vent hoses cracking, etc... since i have driven both on numerous occasions i feel the v6 is quicker then the supercharged 4 cylinder. sounds better too. just my opinion
Streetglower is offline   Reply With Quote
Old 02-27-2008, 07:31 PM   #3 (permalink)
Date registered: Feb 2008
The V6's are having a few issues with camshaft adjusters, but i have to say overall the V6 is 10 times better than the 1.8
Mattfan is offline   Reply With Quote
Old 02-27-2008, 08:39 PM   #4 (permalink)
Date registered: Aug 2007
Vehicle: 2006 C230 Sport
It's been a while since I've driven a 4 cyl 230; my son had one of the first SLK 230 Kompressors and I got to keep it while he was on deployment. I think it was faster than my present '06 230 sport, but the V-6 feels like it has more torque. I never really extended the SLK (How do you say "Sorry, kid; I wrecked your car while you were off fighting the Arabs!" but I know he managed to scare himself enough that he traded it in on a Boxster.
Geezer1 is offline   Reply With Quote
Old 02-28-2008, 03:13 AM   #5 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
I drove plenty of 04-05 C230k sedans and 06-07 C230 sedans for loaner and just cars between friends.
the C230k is more fun to drive, the older 5 spd auto is more responsive and doesn't hunt the gears like the C230 with their 7 spd.
which is quicker...I would probably say the C230k with the M271 ever so slightly because it weight less and only loose 10hp. torque rating's similar.
which handles better...I would pick the C230k as well because it's lighter up front.
which has better gas mileage...you guessed it the C230k.
which is more refined and sounds better...I would probably give the C230 with the V6 the nod.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 02-29-2008, 09:27 PM   #6 (permalink)
What is the camshaft adjuster problem
My check engine light starting coming on after 35,000 miles on my 06 and I took it in to the dealer and they told me they had to replace the cam actuator. What exactly is this and what was malfunctioning. Would this be an expensive repair if the car wasnt under warranty?
speednchrome is offline   Reply With Quote
Old 03-03-2008, 06:34 AM   #7 (permalink)
Date registered: May 2005
Vehicle: 2005 C230 K
my personal opinion (and it may be a biased opinion b/c of what i have), is that the c230k is a better performing car...especially with the manual...the manual's response time is definitely noticeably quicker than the v6's. but it's not just my opinion...everyone i've actually spoken to prefers a manual kompressor over the v6.
blk05c230k is offline   Reply With Quote
Old 03-03-2008, 10:55 AM   #8 (permalink)
Vehicle: 2004 C230 Kompressor Sedan; 1975 Triumph TR6
the Kompressor engine is about .8sec quicker to 60mph in Manual and 1sec faster in Auto.
This is based on MB data.
The Kompressor has 11 lb-ft more torque and weighs 165lbs less (off the front end)
The torque curve is flatter in the Kompressor and has a wider range of torque
There is at least 180lb-ft from 2000-6000RPM
a picture is worth a thousand words but a feeling is worth a thousand pictures
stevenh is offline   Reply With Quote
Old 03-04-2008, 12:10 AM   #9 (permalink)
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 05 C230WK-05 E320CDi
After having driven a bunch of 05 C230k loaners I was really thinking of getting one to use as a daily driver but held off until I could drive an 06 with the new multivalve V6 and the 7 speed auto. After finally getting a chance to play with the new 06 model I rushed back to the dealer and purchased the last 05 kompressor he had in inventory.
I think they finally got the drivetrain sorted out with the 3.0 engine on the W204 but I don't like the fact that Mercedes is following the Japanese cars with the higher beltline and smaller windows.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline   Reply With Quote
Old 03-04-2008, 07:58 AM   #10 (permalink)
Vehicle: C320 4matic
Send a message via AIM to Tri-Star
Go with a 6 ... any type of forced induction leads to problems in the long run. More parts to replace once they go bad.
Tri-Star is offline   Reply With Quote
FS: 2007 C230 janos_z For Sale, Trade & Wanted Items 0 02-04-2008 12:49 PM
Need Help...2007 C230 Broke Down nikki625 W203 C32 AMG, C55 AMG 1 05-22-2007 06:33 PM
Just got a 2007 c230 diazc230 W203 C-Class 6 02-20-2007 10:19 PM
2007 C230 samsam12341 W203 C-Class 5 02-15-2007 05:39 PM
2007 C230 MWalker Audio & Telematics Forum 0 12-28-2006 05:06 PM
