Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 12-28-2007, 08:12 PM   #1 (permalink)
Date registered: Nov 2006
Vehicle: 92 190E 2.6, 99 C230, 87 Porsche 944
Im buying a W203 Tommrow !
Im buying a sweet looking 2004 Mercedes C230 SPORT with 30k. Awesome looking car. I have a few question about it.
Where the hecks the battery at (Ive looked and looked)
How easy is the tiptronic to operate
Any problems with these cars
Wizz190E is offline   Reply With Quote
Old 12-28-2007, 08:19 PM   #2 (permalink)
taxi615's Avatar
Date registered: Apr 2007
Vehicle: 2002 c230K black coupe
bat. should be under the hood top right hand side under the AC air filter.
shifting I dont know I have 6 gears man.
bilstein and eibach, azenis 225-50-16, K&N filter, boost and air/fuel meter, Phillips H7 4000K light all around. Tinted windows, ZEX 100 shot.
75 shot=1/4 mile: 13.961@107.76
comming up: ASP pulley, crank pulley, ECU flash (powerchip), PSS9 coil over kit, big brake system, sway bars all around, brake lines, remus with supersprint headers, 255lph fuel pump...maybe 17''.
taxi615 is offline   Reply With Quote
Old 12-29-2007, 09:15 AM   #3 (permalink)
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 02' C230 Kompressor Sport Coupe (M111)
The tiptronic manual automatic is very strange. It will not allow you to upshift if the RPM's are too low, and it does not respond to your input fast enough. Seems like a one, or two second delay before it even shifts. Say, you are cruising at 60MPH in 5th gear, and want to downshift to the lowest available gear at the speed you are traveling. You can hold the tiptronic in the downshift position for a few seconds, and it will automatically select the best lower gear. Then if you want to get out of tiptronic fast, you can hold it in upshift position for few seconds to put back into full automatic. Another good feature is that it will automatically upshift for you in tiptronic mode if you forget to do it yourself, and hit the redline.
My Car; 02' C230 Kompressor Sportcoupe [115,000 Miles]
Modifications: ASP Overdrive Pulley - NGK Iridium IX Sparkplugs - Kompressor Silencer Removed
---------------- Clear Side Indicator Covers
My Website; Internet Database Website
My Forum; I.D.W. Forum
2002c230 is offline   Reply With Quote
Old 12-30-2007, 05:34 AM   #4 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
it does allow you to upshift manually. just tap right. i can even do this with my sister's 00 clk320.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 12-30-2007, 08:25 AM   #5 (permalink)
2002c230's Avatar
I know it allows you to upshift manually. What I was saying is that it will not upshift until you have reached which is set as an acceptable RPM. Say you are in first gear, traveling 5MPH at around 1k RPM's. If you manual shift up into second gear, it shows "2" on the MFD, but will not shift until you climb up to higher RPM's.
Old 12-30-2007, 01:42 PM   #6 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
It's still an automatic, it just lets you select gears but doesn't necessary mean it will go into the chosen gear.
Old 12-31-2007, 04:27 AM   #7 (permalink)
I think you are misunderstanding what I've said. what I meant was you don't have to have the MFD shows "2" for it to up shift. It can show "D" and when you tap right it will up shift even if you are going 5mph and in first. I do this all the time with my own car and my sister's car.
Old 12-31-2007, 04:54 AM   #8 (permalink)
Date registered: Aug 2006
Vehicle: 2006 C230 Sport sedan
The battery is right under the cabin air intake (near right side hood hinge), which make no sense to me, as I would think that it could induct battery gases into the cabin (???)
The triptronic (auto tranny) is interesting and takes a little getting used to. I find it useful in down shifting 1 gear when going up a steep hill. The short coming is that it then does not shift up until you tell it. A better set-up would be if it just shifted down/up 1 gear based on your command and then resumed 'normal' operation. It is useless as a manual shifting alternative - too much delay in the shifting to really give you the control of a manual tranny.
I also use triptronic when driving in snow. . . I generally run in 3rd or 4th gear in order to keep the engine revs up a bit while pushing through deep stuff. O BTW - the car is really bad in snow. You will have to learn when to de-activate the ESP and that sort of thing. I'm in my second winter season and still getting the hang of it. Even so, you'll be one of the first ones to get stuck in the snow.
Reliability of these cars is spotty, lots of little stuff goes wrong. Hopefully yours will have the bugs worked out.
Best attributes of the car are the looks and driving experience.
tpenfield is offline   Reply With Quote
Old 01-01-2008, 03:32 PM   #9 (permalink)
2002c230's Avatar
Yes, I see what you're saying now. I do that a lot myself. Lately I have just been using the amount of gas applied to have it shift where I want.
Old 01-02-2008, 10:22 AM   #10 (permalink)
BF_JC230's Avatar
Date registered: Oct 2003
Vehicle: 1980 w123 230 "Sport", 2005 w203 230 Sport
Send a message via AIM to BF_JC230
Car is not that bad in the snow...I can pass Jeeps in my winterized w203...
Can I ask what you will be paying for the car?
I have a 6 speed.
The battery is a vented example that uses an exterior exhaust tube to remove the potential battery vapor away from the cabin and engine bay - INSURE that any replacement battery also has a vent tube!
I would think that by 30,000 miles the PO and the warranty took care of most small items...
Things I notice...
1. Car tracks to the crown of the road easy
2. Make sure your radio is coded - eve so - mine will create static or make a no CDC sign
3. People seem to bottom out the front easily
4.
Jake
BF_JC230 is offline   Reply With Quote
first fox, now FBI and CIA too.. tommrow may be whitehouse itself theboss Off-Topic 1 08-22-2007 06:08 PM
help with W203 jayzo General Mercedes-Benz 0 07-31-2007 01:03 PM
My Second W203... BenzofBend W203 C-Class 6 09-01-2005 09:21 PM
[Buying] Clear Side Markers for W203 C230 Benz Cappa26 For Sale, Trade & Wanted Items 2 07-06-2005 07:52 AM
w203 Phat_Benz Test 2 08-05-2004 08:35 PM
