Help, Help, C320 Brake Problem, ESP, ABS, BAS!!!! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-16-2007, 08:56 PM Thread Starter
Date registered: Dec 2007
Angry Help, Help, C320 Brake Problem, ESP, ABS, BAS!!!!
I have a 2001 Mercedes C320 and it recently started flashing the following error codes on the dash; ESP, BAS, ABS and then it said Brake Lining Wear Visit Workshop. The computer also retards the engine and the car only goes about 30 miles per hour when these error codes are flashing. This probelm is intermittent and sometimes I can drive 30 to 40 miles before it does it. Other times the error codes flash as soon as I start the car. I had the rear brakes replaced about six months ago and I thought that the front brakes may be causing the problem, therefore I just had the front pads and rotors replaced. The shop also replaced the front brake sensors as well. I then thought it may be the brake switch so I bought one from Walter's Mercedes and just replaced that too. The computer still flashes the ESP, BAS, ABS, Brake Lining Wear Visit Workshop Error Codes. Does anyone know what else the problem could be??? I am planning on taking the car into a local Mecedes Benz repair shop in the next few days, but would like to fix it myself if possible. We have a new baby and buying the formula food and diapers is killing me so I'm trying to save as much money as possible. Ten Thousand Thank You's!!!
no bad days is offline
post #2 of 3 (permalink) Old 12-21-2007, 07:40 AM Thread Starter
Can anyone help give me some advice in this area??? If not, does anyone know a good Mercedes Benz mechanic in the Upland, Ontario California Area???
post #3 of 3 (permalink) Old 12-21-2007, 02:38 PM
Date registered: Apr 2006
Vehicle: 2002 c320 wagon
Angry Update
After dealing with the draining battery issue, I thought I fixed it with unplugging the potentially defective Power Seat Modules. That led to the next problem of brake lights malfunctioning, abs msg, brake lining msg, visit workshop etc. The other problem were phantom headlights. With the car turned off the headlight would suddenly go on, not both but the left headlight only. The only way I could turn off the headlight was to disconnect the battery.
I brought the car in for service and they discovered I had a defective SAM. After spending $830 and no car for 3 days, I got the car back and it seems fine again.
I am not happy about having to pay for expensive repairs on a 2002 Mercedes with 43000 miles on the odometer. Not a very good experience.
PWGUNNY is offline
BAS, ESP, ABS problem.....DIY repair bbearden26 C208/A208 CLK-Class 13 06-17-2014 12:26 PM
ABS/BAS-ESP lights on - Brake lights don't work niwred W210 E-Class 12 11-27-2013 03:53 AM
Thrill Kill, got a question about the ABS/ESP/BAS problem LorinserCLK55DTM C208/A208 CLK-Class 6 02-07-2006 03:02 PM
ABS/BAS-ESP lights on and no brake lights niwred W210 E-Class 3 11-28-2004 04:48 AM
ESP/BAS & ABS problem chopper W168 A-Class 1 06-14-2004 07:34 AM
