» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 03-06-2008, 02:08 PM   #11 (permalink)
Date registered: Jul 2003
Vehicle: 2003 C230K 6spd, 1996 Integra RS
Service Bulletin Num : 032006, NHTSA Item Number: 10000630, ENGINE OIL LEAKS. *TT
^ i guess.
if anyone can post the part number to the replacement camshaft sensors, that would be very helpful. that is the point of this sticky, isn't it?
reno
- '96 Integra RS (mine)
- '03 C230K C-Coupe (hers)
reno96teg is offline   Reply With Quote
Old 03-17-2008, 11:45 AM   #12 (permalink)
Date registered: Oct 2005
Send a message via AIM to tozfeekum
Originally Posted by taylor192 View Post
Confirmed with the dealer - the cam magnet sensors are leaking on high mileage M271 engines.
Its a $500 part and 6hrs of labour to replace the engine harness.
The typical failures are the O2 sensors as the oil destroys the sending units.
So far this year:
$300 MAF
$250 for both O2 sensors
Now:
$100 cam magnet sensors
$500 engine harness
$250 possibly new O2 sensors since the CEL is back
My car is at the dealership today and i have this problem also, he quoted me 3700 to fix it......someone come out with with a DIY please!? Taylor, how hard is replacing everything?
tozfeekum is offline   Reply With Quote
Old 04-10-2008, 08:39 AM   #13 (permalink)
Date registered: Nov 2007
Hi all,
I've been lurking for a while and really appreciate the information available here on the boards.
I have a 2004.5 C230K SS it just turned 79K miles. I bought it used 5 months ago with 63K miles on it. I just took it in for the PCV service campaign last week. I purchased the cam sensor starter leads at that time. I had check my cam sensors 30 day ago and they were fine. But when I went to install the "adapters" I noticed one started leaking. So I'm ordering a set right now. My question is do the new sensors come with new o-rings or do these need to be ordered separately? There is also a plug listed do I need to order that too?
Any help would be greatly appreciated.
Thanks!
hpuxsux is offline   Reply With Quote
Old 04-27-2008, 12:10 AM   #14 (permalink)
The part number for the cam magnet sensor with o ring is A271 051 01 77 . Listed for $66.00. I think it's a diy if you have a star socket set.
santie420 is offline   Reply With Quote
Old 04-28-2008, 05:30 PM   #15 (permalink)
Date registered: Jun 2007
Vehicle: 2005 C230 SEDAN
I changed mine out over the weekend and these were the parts I needed.
2x - 271 051 00 32 - Expansion Plugs
2x - 010 997 23 48 - Seal Rings
2x - 271-150-27-33 - Isolating wire
2x - 271-051-01-77 - Cam sensor
2005 C230 Kompressor Sedan
ermtpa is offline   Reply With Quote
Old 05-02-2008, 11:29 AM   #16 (permalink)
Date registered: Apr 2008
Vehicle: 04 C230K SS
ermtpa, how much did all of that cost you and about how long did it take?
phate is offline   Reply With Quote
Old 05-04-2008, 09:33 PM   #17 (permalink)
Date registered: Sep 2007
Even though I have error codes for both cam sensors, I checked them today for oil and they were perfectly clean! does anyone know of these sensors going bad for reasons not related to the oil leakage??
ruizmilton is offline   Reply With Quote
Old 05-05-2008, 06:57 AM   #18 (permalink)
It cost about $160 for the parts (AutoPartsPeople.com - Genuine factory Parts and Accessories) and less than an hour to install. Would have taken a little less time if I didn't drop the bolt into the engine and have to take off the bottom plate to get it back out.
Old 05-19-2008, 01:50 PM   #19 (permalink)
BF_JC230's Avatar
Date registered: Oct 2003
Vehicle: 1980 w123 230 "Sport", 2005 w203 230 Sport
Send a message via AIM to BF_JC230
Talking
Just a note - I installed the cam starter wires this weekend with my Dad...(May 17th, 2008) and the car had 33,616 miles - NO OIL or anything to worry about in my M271...
Thanks all,
Jake
BF_JC230 is offline   Reply With Quote
Old 06-14-2008, 02:59 PM   #20 (permalink)
Vehicle: 07' ML 320 CDI
Hey man we see this all the time at the dealership we look at it as gravy considering you can replace the wiring harness in about 2-3 hrs make sure you don't have any oil at your M.E. control module either I have had that one bite me before anyway the source as you probably know is the cam adjuster magnets Mercedes has come up with a updated part number as for any bulletins I dont think there is any for the 271 just the 111 but hopefully all goes well let me know if I can be any more help
MbTechGeorgia is offline   Reply With Quote
DIY-M271 oil change...sort of BF_JC230 W203 C-Class 19 05-31-2009 11:15 PM
M271 Exhaust Manifold pugguy2001 For Sale, Trade & Wanted Items 0 08-17-2006 12:24 PM
M271 BS Boost Kit Kentzee W203 C-Class 5 01-06-2006 09:43 AM
FS: M271 Kleemann Pulley Kit neoequinox For Sale, Trade & Wanted Items 1 06-03-2005 05:45 PM
M271 C200 Kompressor vs V6 C240 VBlaster W203 C-Class 4 11-07-2004 08:30 AM
