» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 09-08-2007, 07:42 PM   #1 (permalink)
Date registered: Jun 2007
can you use e85 in a 2004 c230?
being a new benz owner, I have a 2004 c230. I got bad advice and put a tank of e85 in the car. The check engine light came on. Will this damage anything?
shelnick is offline   Reply With Quote
Old 09-09-2007, 11:52 AM   #2 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Welcome to the forum but you didn't have to wait until you destroyed you car to chime in. E85 is 85% alcohol and you car is not mean to run on it, so it will run poorly, probably misfire codes. I doubt one tankful makes a huge difference in the life of your engine and if you car runs OK just burn it through, otherwise empty as much as possible and fill it up again with premium. Most gasolines now have 10-15% alcohol anyway.
Resetting the light is easy, just get a OBD2 scanner, plug it in (connector is near the parking brake release handle) and reset it. These days it's crucial to have a scanner to do any work on the car yourself.
Old 09-09-2007, 03:27 PM   #3 (permalink)
Cool. Thank you for the insight. Will the check engine light go out, or will it need reset?
Old 09-09-2007, 11:58 PM   #4 (permalink)
Date registered: Jan 2007
Vehicle: 2003 C240 4Matic
[quote=Buellwinkle]Welcome to the forum but you didn't have to wait until you destroyed you car to chime in. E85 is 85% alcohol and you car is not mean to run on it, so it will run poorly, probably misfire codes. I doubt one tankful makes a huge difference in the life of your engine and if you car runs OK just burn it through, otherwise empty as much as possible and fill it up again with premium. Most gasolines now have 10-15% alcohol anyway.
Just like that.
Whosdis is offline   Reply With Quote
Old 09-12-2007, 06:24 PM   #5 (permalink)
The scanner worked great. Thank you for the help! everything seems to be fine.
2003 C320 can use E85 fuel? saimasta W203 C-Class 9 05-29-2007 11:25 AM
E85 fuel mtiede R171 SLK Class 3 05-11-2006 09:26 PM
E85 Benz? Atoche General Mercedes-Benz 1 05-07-2006 11:08 AM
E85 fuel mickey.1430 W163 M-Class 4 03-03-2006 01:16 PM
