» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 09-04-2007, 05:17 AM   #1 (permalink)
Date registered: Aug 2007
ON-Board Diagnostics connector
HI,
Can the OBD2 scanner tool be used in a mercedes car specifically a w203? And if yes, where is the 16 pin connector located in the car? thanks in advance.
bluecoupe is offline   Reply With Quote
Old 09-04-2007, 06:17 AM   #2 (permalink)
BF_JC230's Avatar
Date registered: Oct 2003
Vehicle: 1980 w123 230 "Sport", 2005 w203 230 Sport
Send a message via AIM to BF_JC230
Next to the hood release...
BF_JC230 is offline   Reply With Quote
Old 09-04-2007, 07:16 PM   #3 (permalink)
thank you for the response BFJC230. Will that locally available scanner work with w203 cars specifically in resetting fault codes? thank u again.
Old 09-04-2007, 11:17 PM   #4 (permalink)
Date registered: Jan 2007
Vehicle: 2003 C240 4Matic
It should.
Whosdis is offline   Reply With Quote
Old 09-05-2007, 08:49 AM   #5 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Some do, some don't, some work partially. Make sure you keep the receipt.
Old 03-20-2008, 06:12 AM   #6 (permalink)
morser's Avatar
Date registered: Jun 2005
Vehicle: C 230 Coupe K
What do you use?
Buellwinkle or others,
What brand/model of ODB2 tool do you use for checking issues? I'm shopping around.
MOrser
2002 C230K Coupe Evolution Package
morser is offline   Reply With Quote
Old 03-20-2008, 08:44 AM   #7 (permalink)
BenzWorld W203 Host
I use software from OBD-2.com and it's worked on every car I've tried it on. They also have vehicle specific codes which is nice. The nice thing about software is that it's easily updateable and I can log and keep sensor logs for as long as I want and if the hardware breaks, I still own the software.
A/C DIAGNOSTICS NEED HELP rodsoriano W140 S-Class 1 08-28-2007 10:28 AM
400E on board diagnostics Rahray W124 E,CE,D,TD Class 1 09-30-2006 08:23 PM
Diagnostics BIFFO-911 General Mercedes-Benz 1 07-11-2006 08:00 AM
Lighted step-board / running board tv-nuts W163 M-Class 4 12-19-2003 02:32 PM
New on this Board, but old on SLK Board... Need input on '01 E55... HarleyB W210 E50 AMG, E55 AMG 3 12-02-2003 09:09 AM
