Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 07-02-2007, 11:47 AM   #1 (permalink)
Date registered: Jan 2007
Vehicle: '06 C230, '91 Acura Legend Coupe
aftermarket auxiliary input for 06 c230
found this on crutchfield... will it work?
Precision Interface Electronics BLAU/8-RCA Auxiliary input adapter with RCA jacks for Blaupunkt stereos at Crutchfield.com
'91 Legend coupe
190,000 miles and counting...
legendtype2 is offline   Reply With Quote
Old 07-02-2007, 09:27 PM   #2 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Did you replace your radio with a Blaupunkt? If so, yes. If you have the factory radio, search the forum, there's a cable you can get at the dealer that you plug in on the passenger side footwell area that gives you aux in but it won't work with a Blaupunkt radio, only the MB factory installed radio.
2007 C230 Aux Input Help Kotomi328 W203 C-Class 16 07-21-2008 04:35 PM
Sony In-Dash CD Player with Auxiliary Input (CDXGT100) Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 2 10-27-2006 10:51 AM
aux input on 05 c230 kompressor? Wing689 W203 C-Class 1 07-07-2006 05:57 AM
w208 COMAND auxiliary input or MP3 CDs? SCoallier Audio & Telematics Forum 4 11-30-2005 09:43 PM
Aux Input on Aftermarket System. OneMnk W123 E,CE,D,CD,TD,TE Class 0 01-09-2005 09:55 PM
