Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-13-2007, 09:49 PM   #1 (permalink)
Date registered: Jul 2005
What spring gives the lowest drop?
Guys, what spring would give me the lowest drop?? Would different pads help also? I am running 19" wheels now and prefer no gap.Thanks
BUSTN is offline   Reply With Quote
Old 06-15-2007, 11:37 AM   #2 (permalink)
Date registered: Feb 2007
Not sure which spring gives the lowest drop, but I have heard that the Eibach's barely drop the car at all. People seem to be happy with H&R Springs, or the whole H & R cup kit. Tein springs give you .8-1.8" drop depending on your model. For ultimate adjustablility, you can get Tein coilovers.
The pads are only for the rear springs. Depending on how wide your rear tires are, you might not want to drop the rear too much. If the rear tires are 265/35/19, the tires will probably rub, and you will need to roll the fenders. Also, there is more wheel gap in the front than the rear with the stock setup. I personally prefer to have the front look lower than the rear, to have the racey look.
If you use a thinner pad on the rears, your rear wheels will probably tuck, and the fronts will not. If you prefer the rear to tuck, then a thinner pad for the rear would be what you want.
2004.0 C230 Sport Sedan
OEM Bi-Xenon 6000K. LED Taillights. Updated Foglights 6000K. Euro Clear Bumper Lights. W211 style Mirror LEDs. 05 C230 Springs. Stainless Exhaust Tip. 05 OEM Shift Knob & Sport Grille. 2 x 12" MTX Subs. 07 Chrome SmartKey. 20% 3M Tint. Hawk Ceramic Front Brakes. Akebono Ceramic Rear Brakes.
Coming Soon: 19" Wheels, Pioneer AVIC-D3 + Amp + MB Quart Speakers.
XenonBenz is offline   Reply With Quote
Old 06-15-2007, 07:27 PM   #3 (permalink)
MJ50's Avatar
Date registered: Nov 2003
Vehicle: C240 & ML350
Send a message via ICQ to MJ50 Send a message via AIM to MJ50 Send a message via MSN to MJ50 Send a message via Yahoo to MJ50
try H&R springs...
but for a perfect drop, go with coilovers...
2003 C240 done modding
2004 E55 MBenzNL, RENNtech pulley, ECU, VRP split cooling
2004 ML350 modded & sold
MJ50 is offline   Reply With Quote
Old 06-17-2007, 09:50 AM   #4 (permalink)
WaveyKat's Avatar
Date registered: Aug 2004
Vehicle: 2K1 C320 SS
Send a message via MSN to WaveyKat
Originally Posted by MJ50
try H&R springs...
yes H&R gives the lowest Drop but the front will still be kind of high so Coilovers will be your best bet.
WaveyKat is offline   Reply With Quote
Old 06-17-2007, 03:55 PM   #5 (permalink)
Can the H&R coils still be cut, if they are not low enough?I am running 235/35 and 265/30r19's.
Old 06-18-2007, 06:50 AM   #6 (permalink)
Yes, you can cut any spring, but you will most likely get a very bouncy ride. It sounds like coilovers will probably be the best fit for you. Tein basic coilovers cost about $800.
Old 06-18-2007, 08:38 AM   #7 (permalink)
Date registered: Jan 2007
I have H&R and my front is way higher then the back
EuRo RiCe is offline   Reply With Quote
Old 06-18-2007, 08:39 AM   #8 (permalink)
I would just go with the tein basic or SS
getting clk lowest as possible.. Phade W208 CLK Class 34 10-01-2006 12:43 PM
whats the best sport spring out there to drop a clk500 hotboy W209 New CLK Class 5 03-04-2005 09:12 AM
Lowest mileage 190 Guest (MBNZ) W201 190E, D-Class 9 12-23-2003 04:44 PM
anyone with a 17" rims and didn't drop the car with spring? ahh01010 R170 SLK Class 6 02-15-2003 10:03 PM
has anyone lowered thier CLK's with just the lowest spring pads? (more) techB W208 CLK Class 4 10-23-2001 02:17 PM
