» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 03-13-2007, 12:58 AM   #1 (permalink)
Date registered: Mar 2007
Bi-Xenon headlight aiming
My car - '03 C240 w/BiXenon headlights. Problem - lights aimed a bit too high. The lights go through their self-check OK, they maintain aim with varying loads in the trunk (compensation seems OK), they are both pointed straight ahead and exactly the same height. All I need to do is aim them a little lower so I'm not offending oncoming drivers constantly. There must be a simple height adjustment that is easy to access - right?
mikapen is offline   Reply With Quote
Old 03-13-2007, 02:38 PM   #2 (permalink)
Vehicle: 2003 C320 2004 lexus is300
Send a message via AIM to saimasta
I have a '03 C320 w/BiXenon headlights also and I have run into the same issues. I have pretty much ignored it because I asked my dealership and they told me thats how they are... I am also trying to find a solution, but these lights illuminate the dark and piss many drivers off thinking im using high beam. If you find a solution, please let me know.
saimasta is offline   Reply With Quote
Old 03-14-2007, 12:31 AM   #3 (permalink)
bensitto's Avatar
Date registered: Jan 2003
Vehicle: 2001 C320, ML320
You can adjust them manually or via Star Diagnostic at the dealer.
But if I were you I would keep them how they are. Mine are pretty high and I love it cause they illuminate everything very far out. If you move them lower you will cut the distance that you can see.
I have Xenon fog lights too. So I have very bright light. People seem to ignore it cause there are so many cars with xenon light these days.
<EMBED src="http://www.bodmerdesign.com/Benz/2008_sig_bensitto.swf" quality=high bgcolor=#FFFFFF WIDTH="720" HEIGHT="168"
</EMBED>
bensitto is offline   Reply With Quote
Old 03-14-2007, 11:07 AM   #4 (permalink)
Date registered: Jan 2006
Vehicle: 2004 C230 Sport Sedan, 2005 C240 Wagon
There is a large, black plastic nut just behind the headlight housing. Looking down, you will see the top of the nut. It is recessed behind the housing and if you look carefully at the housing, the housing should have arrows showing which way to turn the nut to adjust the aiming point up or down. Although the nut has a giant screwdriver receptacle, using a properly sized socket with an extension bar is a lot easier.
ATL_MB is offline   Reply With Quote
Old 03-14-2007, 02:27 PM   #5 (permalink)
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 05 C230WK-05 E320CDi
There are actually two black adjusters on the back of each light. If your car has the DOT lights that were OEM installed the one that is covered with a black plastic guard should be left alone as even most dealers are not set up to mess with this adjustment. If your car has lights from any other source including Mercedes parts from Europe the black plastic guard may not be there so it is important you adjust the correct one.
If you need a picture of which one is the correct one let me know and I will post a picture. Since your car is an 03 it could not have had Bi Xenon as original equipment so make sure it is actually a Bi Xenon. They are projector beam assemblies and not reflector based. Make sure you are careful when adjusting that you do not exceed the mechanical limits of the adjuster. The adjuster block can fall off the screw threads if you turn it too far and most dealers will not fix that.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline   Reply With Quote
Old 03-15-2007, 04:31 AM   #6 (permalink)
Tom4697's Avatar
Date registered: Aug 2006
Vehicle: '06 E350
I'm pretty sure the Bi-Xenon was an available option(OEM) in the 2003 c-class sedan.
(Not available in the c-class coupe till 04, though.)
T.
Today will be tomorrows history, make it count.
Tom4697 is offline   Reply With Quote
Old 03-15-2007, 09:00 AM   #7 (permalink)
n5160u's Avatar
T.
Regular Xenon with the engraved headlight lens and reflector was the only option until the facelifted models came out. The facelift (MOPF) models had crystal clear lens for the halogen with Bi-Xenon projectors for the lighting package option and were sold in the USA starting with the 2005 models. The facelifted 05 models went on sale in the USA in May, 2004. One other way to identify the facelift models is their instrument cluster has four analog guages (Tach, Temp, Fuel, Speedo) with white lighting. The pre-facelift models have three analog guages (Tach, Speedo, and Fuel) with orange/amber backlighting.
Old 03-15-2007, 08:38 PM   #8 (permalink)
JimB's Avatar
Date registered: Jul 2002
Vehicle: ML320/C320 Sprt
My 03 C320 sport have a Bixenon option from the factory.
2000 ML320 Black Opal
2003 C320 Sport Sedan Bordeaux Red
1996 Honda Civic...
1991 Black Nissan Truck
2005 Honda CR-V EX AWD...New Add on to my Toys...
Trek, Full Suspension Mt. Bike
and a Dog, name Abby;-)
"Life is Short, Let's Enjoy It"
JimB is offline   Reply With Quote
Old 03-16-2007, 01:33 PM   #9 (permalink)
My 2004 sedan (delivery in early November 2003) came from the factory with bi-xenons. FYI - If you back the xenons off the screw, they are easily fixed (pull the black cover off the back of the headlight housing, reach in and lift the buld package thing until it contacts the screw, and screw it back on by turning the adjustment nut).
Headlight/Foglight Aiming '91 300CE W124 E,CE,D,TD Class 4 12-13-2006 05:43 AM
Help with headlight aiming 79Mercy W123 E,CE,D,CD,TD,TE Class 4 11-25-2006 08:19 PM
Headlight Aiming? RHoodJr W163 M-Class 8 09-24-2002 08:36 AM
Headlight aiming and door questions Howard R170 SLK Class 3 08-04-2002 09:11 PM
bi-xenon aiming Iwan W163 M-Class 2 02-23-2002 08:02 PM
