» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 03-03-2007, 12:41 AM   #1 (permalink)
Vehicle: 2001 Mercedes C240 6 spd.
Wipers only work when car is moving
Hello,
I have a 2001 C240 and have had a *few* problems thus far. A bad mass air flow sensor at 90k, which I was told is common, and this weird Clanking noise that I hear whenever I make a turn or hit a bump. The most recent problem is the windshield wiper problem. Whenever I turn on my wipers and the car is sitting still, they do not work. At all. When I am moving they work fine. For example, I could be driving 35 mph and come to a stop light. As soon as I come to the stop, the wipers stopped right where they are at. I'm afraid it may be the windshield wiper motoring going bad, but would like some input as to what else it may be. As far as electrical work being done to the car, I've replaced the alternator, battery and spark plugs all within the past 5k miles.
Also while I'm asking the question, does anyone have insight as to what the clanking noise I am hearing when I make turns and hit bumps? It comes from the rear of the car. When the noise was first heard, it was only when I went over a large bump or pothole. Now, it seems whenever I hit a small bump or make a turn I hear the noise.
Thanks!
dc1984us is offline   Reply With Quote
Old 03-03-2007, 07:27 AM   #2 (permalink)
sunman's Avatar
Vehicle: 2003 C320 Sedan, 1992 400e sedan
Send a message via AIM to sunman
the noise is probably a broken sway bar link or suspension issue. I would have it checked out. As for the wiper system, there is a rain sensor on teh glass. If you put in in the first position, it should do what you state. If it rains heavy and you come to a stop, it wipes slowly at the light. It will not wipe if you come to a stop and open the drivers door or open the hood.
2003 c320 Sedan - Completely updated to 2005 spec with all euro and usa options
2002 s500 Sedan - Completely updated to 2006 spec with all USA options and some euro options.
http://web.mac.com/motorwerks
sunman is offline   Reply With Quote
Old 03-03-2007, 03:58 PM   #3 (permalink)
Thanks for the advice on the suspension/sway bar link. That would explain a few other things such as handling issues.
As for the wipers, my windshield washer fluid doesn't even work except when the car is moving. If I am not moving and try to use my windshield washer fluid, which also uses the wipers (stating the obvious), it will not work. But as soon as I get moving I can use it. The rain sensor works. When the car is moving and I have the wipers switched to the first position, they work as they are supposed to. I cracked the windshield a few days ago so I'm getting a new windshield with rain sensor and blue tint (I don't have that now) Monday. Any other ideas?
PLEASE HELP ! ! Wipers don't work.. beachbummer505 R/C107 SL/SLC Class 9 07-03-2008 08:50 AM
Intermittent Wipers do not work jetmal W163 M-Class 8 06-08-2006 01:20 PM
Wipers work sometimes Nimrodthewombat W140 S-Class 6 04-19-2006 09:41 AM
My windshield wipers don't work eyegotta75_240D Vintage Mercedes-Benz 1 11-16-2005 07:24 PM
wipers moving in opposite directions PeterNJ R170 SLK Class 2 12-16-2003 08:22 AM
