Electric folding mirror fault?? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 02-19-2007, 03:00 AM   #1 (permalink)
Date registered: Feb 2007
Vehicle: 2004 C270cdi Avantgarde SE-A and 2006 B200 Turbo with AMG Sport Pack
i have a c220 cdi coupe with electric folding mirrors but they have stopped working correctly so looking for some advise! The indicator on the passenger side has stopped working also and displays as an error on the dash, i have taken the mirror casing off and put it on drivers side connection to check it and the led's worked fine on that side so nothing wrong with them, nor are there any splits in the wire for the indicator on the passenger side so am at a loss as to why this is happening... is there a fuse anywhere?
Also the mirrors are folding in electrically but not out, if you push them back out they stay there, then if you press either fold-in or fold-out button they will fold in, but never fold out electrically... can't be a problem with the fold-out button on the dash as pressing it does do something... just not what it should... ie folds them in and not out!
Has anyone got any ideas how i can fix this and avoid taking it to the stealer!?
iimms is offline   Reply With Quote
Old 05-11-2009, 09:24 AM   #2 (permalink)
Date registered: Apr 2008
Vehicle: CLK320 AMG
Send a message via Skype™ to steve coley
I have the exact same fault on a CLK320 Coupe. Can any body help with this?
steve coley is offline   Reply With Quote
Old 05-11-2009, 04:58 PM   #3 (permalink)
Vehicle: 2004 C230 Kompressor Sport Coupe
Try over in the CLK forum, the C didn't get power folding mirrors in the US so information will be thin on the ground here.
zeet is offline   Reply With Quote
Old 05-11-2009, 05:54 PM   #4 (permalink)
WaveyKat's Avatar
Date registered: Aug 2004
Vehicle: 2K1 C320 SS
Send a message via MSN to WaveyKat
am in the US and have Power Folding mirrors you may want to check the Motor!
WaveyKat is offline   Reply With Quote
Old 05-11-2009, 11:21 PM   #5 (permalink)
Neat, I thought they were either not in the US or incredibly rare.
I would wonder if it's a limit switch of some sort, so it never knows what position it's in.
Old 05-28-2009, 10:33 AM   #6 (permalink)
Date registered: Jul 2007
Vehicle: 1996 SLK230 Kompressor
Hi, Did you get your folding mirrors fixed? Do you know what the cause was for the mirrors only folding in? My guess is it was the Front SAM or the Light/Mirror switch assy but it would be useful to know.
Regards,
Tony
tl99999 is offline   Reply With Quote
Old 05-30-2009, 07:21 AM   #7 (permalink)
Hi, I fixed my folding mirror problem yesterday. It was the switch assembly but could have been the Front SAM. Took it apart and cleaned what looked like liquid damage. May have been the result of condensation though. To test it remove the switch and measure the resistance across pins 2 and 5 - should be around 900 ohms. Press the fold In switch and it should be around 160 ohms. Press the fold Out switch and it should be around 0 ohms. If the mirrors are In and the Out switch doesn't work you can also disconnect the cable from the switch and momentarily short pins 2 and 5. If the Front SAM is good the mirrors will fold out.
Regards,
Tony
Old 06-12-2009, 03:11 AM   #8 (permalink)
Vehicle: CLK320 AMG
Folding Mirrors
Hi Tony sounds like you have the answer to my prob just one thing please explain what a SAM is. Thanks
Steve
Old 06-12-2009, 08:12 AM   #9 (permalink)
The SAM is a computer de-multiplexer. Basically all the control devices (switches) on the car are hooked to the front or rear SAM. Then, all the devices that need to be controlled (lights, motors) are hooked to the front or rear SAM. When you, as an example, step on the brake pedal, the front SAM notices this, generates a command that it sends over the CAN-bus to the rear SAM, and the rear SAM turns on the brake lights. When you switch on the turn signal, that signal goes to the front SAM, which sends commands to the instrument cluster and the rear SAM. The front SAM starts blinking the front turn signals and mirror signals. The rear SAM starts blinking the rear turns signals. The cluster makes the clicking sound and blinks the indicator light. This all seems very complex but it actually simplifies the wiring of the car. If you peek under the dash it's nothing compared to a mid-90s MB, where everything had to run everywhere.
Old 06-29-2010, 03:58 PM   #10 (permalink)
Can someone please tell me how to get access to the mirror switch? is it from the side on the dash on drivers side? near fusebox?
I have had this problem for 2 years mirrors fold in but not out and I am 99% sure its the dam switch!
Anyone got a MB part number for this switch?
Many thanks
delb0y is offline   Reply With Quote
Bookmarks
electric hardtop folding roof theboss General Mercedes-Benz 3 11-24-2006 02:20 AM
Electric seats failing (Yet another fault) smold General Mercedes-Benz 3 10-20-2006 05:05 PM
Electric seats failing (Yet another fault) smold W208 CLK Class 16 05-30-2005 04:54 AM
Electric windows fault (passenger front&Drivers rear) ratter W123 E,CE,D,CD,TD,TE Class 2 11-20-2004 01:28 PM
Those of you who did not order electric folding door mirrors... ianx, manchester R171 SLK Class 3 08-01-2004 12:48 AM
