» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 02-02-2007, 12:47 PM   #1 (permalink)
Date registered: Oct 2006
multiple malfunctions and strange cluster
what's up everyone. i'm new poster on this forum and am looking for a little help.
I've noticed for one week now that my 01 c240 is giving different malfunction messages: light sensor, SRS then occasionally TeleAid. I've also noted there is very ssssllllllooooooooooowwwww transition on the cluster instrument. so when i switch from radio to any other page, that transition show a moment of overlap then a slow transition to the selected menu. I did have a brake bulb go out and i replaced it, but still getting messages. i'm wondering if these may all be early signs of low battery charge. what do you think. i'm trying to do what i can to remedy the issue before i go to the stealership.
thanks
jrey09 is offline   Reply With Quote
Old 02-03-2007, 09:06 PM   #2 (permalink)
Date registered: Dec 2006
Vehicle: 2002 C320
Same symtoms, Original battery was bad, no low voltage malfunction read my post: forum 1295574
http://www.benzworld.org/forums/w203...ht=malfunction
boiler81 is offline   Reply With Quote
Old 02-04-2007, 08:52 AM   #3 (permalink)
I changed the battery and light sensor, teleaid, esp malfunctions are gone. I changed the battery because i noticed head lights would dim when the fan would go on, heater turned on, etc. also had low voltage when i had it checked at advance auto. However, I still have the srs light on, which had turned on last week spontaneously. i checked all the connections under the seats and looks okay. may be a sensor on passenger side, but from what i read these are really pricey.
Old 02-04-2007, 11:45 PM   #4 (permalink)
Date registered: Jan 2007
Vehicle: 2003 C240 4Matic
I also noticed my display taking time to change, but my problem is due to the outside temperature being -40deg.C/-40deg.F.
Whosdis is offline   Reply With Quote
Got 4 Malfunctions 1 BAD BURB W210 E50 AMG, E55 AMG 13 04-19-2007 11:18 PM
94 C220 - Very strange instument cluster/electrical problem PIckes W202 C-Class 4 12-09-2005 06:58 AM
strange instrument cluster actions dell2884 Audio & Telematics Forum 3 10-05-2005 07:57 AM
Strange cluster question 1984 190D 4benzes W201 190E, D-Class 5 05-28-2005 09:21 PM
Brake Malfunctions Ray G500 G-Class 3 05-13-2004 04:40 PM
