Changing fahrenheit to Celsius - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-02-2007, 09:41 AM Thread Starter
I have a 2006 C230, and I was wandering if anyone knew how to change temperature from Fahrenheit to Celcius.
I tried playing around with the steering wheel menu, but the closest I got was to change the temperature indicator to MPH instead of temperature.
Any help would be appreciated!
pazo06C230 is offline
post #2 of 8 (permalink) Old 01-02-2007, 11:13 AM
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
I had an '84 190D with the same problem. I just did this quick thing in my head - (1.8*deg C)+32.
http://www.mylavista.com
Buellwinkle is offline
post #3 of 8 (permalink) Old 01-02-2007, 12:06 PM
MrG
Date registered: Dec 2006
Vehicle: 2003 C240
My 2003 C240 does it thru the menus. It may be because its a Canadian model though??
MrG is offline
post #4 of 8 (permalink) Old 01-02-2007, 03:32 PM
The older W203's had more comprehensive menus. I noticed this when I got a 2006 loaner and I couldn't find a few things in the menus that I'm used to on my 2004.5.
post #5 of 8 (permalink) Old 01-02-2007, 10:07 PM
Vehicle: 2002 C320
On my 2002 C320, you change degrees C to degrees F thru the
"Settings", "Instrument", "Temp Indicator" menu (menu#6 of 9 under instrument).
Now If I could only change the water temp display to degree F?
boiler81 is offline
post #6 of 8 (permalink) Old 01-03-2007, 01:43 PM Thread Starter
I just called MBUSA HeadQuarters. They removed the Cecius feature from all 2006 C230 vehicles. It might be different for Canada, but for US it has been removed.
post #7 of 8 (permalink) Old 01-03-2007, 04:15 PM
Mystery solved. Have you figured out how to set it so steering wheel controls change radio stations from preset to preset instead of just seek? I can do this with my 2004.5 but the 2006+ loaners I get, I can't find that option anymore. Got a C280, quick car, nice.
post #8 of 8 (permalink) Old 01-04-2007, 02:01 PM Thread Starter
No I didn't look into the radio controls, but one thing for sure is that my 06 C230 doesn't have that option, it just seeks for radio stations.
    Fahrenheit to celsius ika W163 M-Class 4 04-25-2006 01:08 PM
    outside temp. is celcius; wanting fahrenheit andthestoryends W126 S,SE,SEC,SEL,SD,SDL Class 9 09-26-2005 11:29 AM
    From mph to km/h and F to Celsius vr43000 R129 SL-Class 0 08-25-2005 08:30 AM
    Outside Temp indicator to Celsius? mrelbe W126 S,SE,SEC,SEL,SD,SDL Class 4 07-19-2005 02:20 PM
    Fahrenheit 911 merouby Off-Topic 21 07-28-2004 01:06 PM
