02 C240 Gas Gage is broken? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-07-2006, 04:30 PM Thread Starter
Date registered: Dec 2006
I have a 02 C240 Sedan and my fuel gage will not move from the empty position. I am guessing it is the fuel sending unit. ANy ideas? If it is that how difficult is it to fix? Only 43,000 miles on it and I just changes my left & right Swaybar links and bushings now I have to replace my rear bushings.
soccer is offline
post #2 of 6 (permalink) Old 12-10-2006, 03:13 PM
Arn560's Avatar
Vehicle: 04 C230 Kompressor
The warranty should be up to 50,000 miles so let the stealership fix it.
Arn560 is offline
post #3 of 6 (permalink) Old 12-12-2006, 03:32 PM
redwood's Avatar
Date registered: Dec 2004
Vehicle: 500E, E320, 190E, E55
Quoted: 13 Post(s)
It could be the gauge itself. I would have it diagnosed at shop.
Redwood
E320 3.2 W211
E55 5.5 W211
500E 5.0 W124
190E 2.3 W201
redwood is offline
post #4 of 6 (permalink) Old 12-16-2006, 04:07 PM
misslovell's Avatar
Date registered: Nov 2006
Vehicle: 2002 C230 Coupe
i've had the same problem i have a 2002 c230. it only does it every once in a while, so when it happens i continue to make frequent stop to the gas station to keep my gas tank full(since i cant tell how much i have).
misslovell is offline
post #5 of 6 (permalink) Old 12-17-2006, 03:50 AM
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
most likely his warranty is out. actually i'll bet 100% his warranty is out.
there's a fuel position sensor some sort. ask the dealership about it. some will be unlucky with a bad unit that does not always work properly. my sister had that thing changed for her 2000 CLK320.
2002 M112K with lots of mods
2008 M272 with some mods
For Sale:authentic Carlsson exhaust tips (2) $100
FrankW is offline
post #6 of 6 (permalink) Old 12-19-2006, 09:35 PM
RE
RE's Avatar
Date registered: Sep 2003
Vehicle: 2008 C300 Barolo Red P2 MM leather 18" AMGs new style folding mirrors + 1984 944
Failed fuel tank senders are a fact of Mercedes life. If you have folding seats, lift up the rear seat bottoms and then the carpet. One on each side for each tank.
Otherwise, remove the rear seat cushion to see them. It takes a special wrench to remove them. If you knew which one it was. When installing one, tightening too much will cause a fuel leak. Inside the car, not a good idea.
RE is offline
    gas gage MBusted W126 S,SE,SEC,SEL,SD,SDL Class 9 07-27-2006 01:45 PM
    gas gage daleneg W163 M-Class 6 07-28-2005 04:37 PM
    Broken gas pump, gas gushing out!! TopDownSLK R170 SLK-Class 8 12-29-2004 12:48 PM
    White Gage faces jdanish W163 M-Class 4 01-24-2004 08:42 AM
    fuel gage (in)accuracy jockm G-Class 9 12-12-2001 08:50 PM
