Tune Up - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-13-2006, 08:50 AM Thread Starter
DETANE's Avatar
Date registered: Mar 2006
Vehicle: 1997 W210 E320, 1999 W163 ML430, 2002 W203 C240
Send a message via AIM to DETANE
Tune Up
It About That Time I Get A Tune Up But I Keep Hearing Different Prices.
How Much Do They Realy Cost?
DETANE is offline
post #2 of 6 (permalink) Old 11-13-2006, 09:23 AM
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
What's a tune-up? How many miles do you have? The plugs last 100K miles and it shouldn't cost more than $100 to replace them.
http://www.mylavista.com
Buellwinkle is offline
post #3 of 6 (permalink) Old 11-15-2006, 07:10 PM Thread Starter
DETANE's Avatar
plugs, cap and rotor, wires, oil, trans oil... how much would that come out to?
DETANE is offline
post #4 of 6 (permalink) Old 11-15-2006, 09:31 PM
I haven't even seen that sort of stuff since I was a kid and I'm 50, haha. Rotors, wires, cap, haha, doesn't exist, how about capacitor and points too?
You can certainly get the oil, trans, rear diff fluids, brake fluid changed probably $250 at a dealer. Plugs depend on which engine you have, the 4 cylinder has 4 plugs, the 6 cylinder as 12 plugs so it would cost more, figure $10/plug at the dealer and 1-2 hours labor. If your car has that high a mileage wher you need plugs, get the serpentine belts and tensioners changed also, probably $300.
post #5 of 6 (permalink) Old 11-17-2006, 11:36 AM
redwood's Avatar
Date registered: Dec 2004
Vehicle: 500E, E320, 190E, E55
Quoted: 13 Post(s)
"Tune up" according to factory consists of spark plugs, fuel, air and cabin filters only. ignition system is maintenance free. Two things -
I would not wait tiil 100K to replace the spark plugs ( i have seen them burned down to the nub at only 63K!) Also, "A" and "B" service reminders indicate an oil service @10K mile intervals, most insiders recommend an oil change every 7K miles regardless using Mobil 1 5w30 only. You can then reset your own service reminder on the dash via steering wheel menus.
Redwood
190e
400e
500e
c240
Redwood
E320 3.2 W211
E55 5.5 W211
500E 5.0 W124
190E 2.3 W201
redwood is offline
post #6 of 6 (permalink) Old 03-22-2007, 02:27 PM Thread Starter
DETANE's Avatar
How do I change the spark plus?
is there any pictorial or step by step thread i can find? i tried the search and was unlucky.
thanks..
Life is the thing that gets in the way of plans.
DETANE is offline
Who can i get to tune my G? Who will tune for the most HP...could this be REALLY bad for engine? sceaton G-Class 2 03-19-2006 06:25 AM
Need Tune Up TheRazz W126 S,SE,SEC,SEL,SD,SDL Class 4 10-09-2005 07:55 PM
tune up JUVENTUZ W124 E,CE,D,TD Class 0 02-26-2004 08:30 AM
Tune-up ssanmor W201 190-Class 7 10-05-2003 04:53 AM
Tune Up Guest (MBNZ) W124 E,CE,D,TD Class 3 06-26-2002 12:12 PM
