» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 11-10-2006, 12:36 PM   #1 (permalink)
spoons's Avatar
Date registered: Mar 2006
Vehicle: 2006 C230 Sedan
Send a message via Yahoo to spoons
2003 C230 Kompressor DIY oil change questions?
I have a 2003 C230 Kompressor Sedan that just went out of warranty/service and instead of giving the dealer $400 for B-service, I'd rather do the work myself. Before I get started I have a few questions:
1. How much Mobile 0-40 oil will I need?
> 5.5 Quarts
2. Should I use an oil extractor or can I drain the oil using the oil plug?
> Palm Beach Dealer still uses drain plug. When the parts guy at the dealer handed me the oil filter box, the drain plug washer was taped to the top.
3. What is the best place on the net to buy MB oil filters? Or is there a better filter to buy?
> Palm Beach MB dealer = $13.00 for MB filter
4. What other additional maintance is done besides new wind sheild wipers, check fluid levels and rotate the tires is in a B-service?
> I have a copy for the Palm Beach MB service checklist..... I will post soon.
Thanks,
Brian Richardson
Jupiter, FL
www.brianrichardson.net
2003 Mercedes Benz C230 Kompressor Sedan
1997 Plymouth Prowler with matching trailer
** Answers to the question are marked by > **
Brian Richardson
Jupiter, FL
2006 Mercedes Benz C230 with 6-speed manual
1997 Plymouth Prowler with Matching Trailer
2003 Mercedes Benz C230 Kompressor (Sold)
1993 Mitsubishi 3000GT VR-4 (sold)
spoons is offline   Reply With Quote
Old 11-11-2006, 08:06 PM   #2 (permalink)
spoons's Avatar
answers
answers listed above.
Old 11-19-2006, 06:55 AM   #3 (permalink)
spoons's Avatar
Posted DIY info on http://www.benzworld.org/forums/w203...your-c230.html
Old 12-13-2006, 08:00 AM   #4 (permalink)
Date registered: Nov 2006
Congrats Brian!I joined the Benzworld recently and found that your posting is very helpful. According to your last one, may I know when you'll be able to post the listing for Service B? Mine is a 05 C230 Coupe (Kompressor). Thanks!
230Kcoupe is offline   Reply With Quote
Old 11-26-2007, 01:22 PM   #5 (permalink)
Date registered: Nov 2007
Changing oil in a 2005 c230.
Hi,
I am a first time buyer of Mercedes, apparently no one mentioned the cost of the oil change and etc. associated with these cars. I would like to do the oil change service myself to save some $. My warranty has expired and I do not qualify for an extension. I have a few questions if someone out there knows the following.
1. Do I need special tools to remove oil and oil filter? As compared to like an American or Japanese built car?
2. I have noticed my car did not come with a dip stick how do I check my oil level?
3. What type of oil do I use and how much?
4. After the oil change how would I reset the service message which appears on my dash board display?
By the way my car is a 4 cylinder supercharged 2005 c230.
Thank you,
Tajinder
Tajinder is offline   Reply With Quote
Old 11-26-2007, 05:50 PM   #6 (permalink)
Date registered: Jul 2007
Vehicle: 2005 C230 Kompressor
How to change your oil and filter.
Originally Posted by Tajinder View Post
Hi,
A:You will need a 27mm socket to remove the oil filter plastic housing located against the firewall.
A:You use the "Check Oil Level" feature on your dashboard display.
0w40 Mobil-1 synthetic, 5-1/2 liters or 5.7 US quarts.
Close the door, turn the ignition on (don't start the engine), toggle to ***miles to service B, hold reset button down, message will appear "hold reset down for 3 seconds to reset service reminder", release and press reset button again until the service reminder changes, done!
Thank you,
Tajinder
Good luck!
John G.
John G. is offline   Reply With Quote
Old 11-27-2007, 10:38 AM   #7 (permalink)
Thank you John. I will try this and let you know what happened.
Old 05-13-2008, 05:20 PM   #8 (permalink)
Date registered: Apr 2007
I just changed the oil on my 02 C230..I need to reset the b service warning..Where is the reset button? I see buttons on both side of stering wheel.
MCIronik is offline   Reply With Quote
Old 05-13-2008, 07:48 PM   #9 (permalink)
Date registered: Oct 2004
Hope this can help you... I recently found out how to reset the service timer on a 2005 C230.
1. Have door closed
2. Put ignition into on position (2nd position) ac fan,dummy lights should be on
3. Toggle through menu find the "A/B service due in ??? miles"
4. Hold reset button @3 seconds
5. Then it will ask you if you want to confirm, then press again
6. Now you are done and can go on your way
rchiu is offline   Reply With Quote
Old 05-14-2008, 09:32 AM   #10 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
I downloaded this from the MBUSA Owners website. I thought it was interesting.
If you notice, there are a lot of "CHECKS", rather than outright replacement.
I suppose most of this, if not all, you can readily do yourself, well before the
Mileage Due Date.
Be sure to update your Maintenance Log Book so you and others know
what services you performed.
A-Service — First visit at approximately 10,000 miles or 1 year, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Interior
· Function check
· Check warning and indicator lamps, illumination and interior lighting
· Check windshield wiper, windshield washer system, headlamp cleaning system
· Reset maintenance service counter in instrument cluster
Wheels, brakes
· Check front brake pads for lining thickness
· Check tires for damage, condition
· Correct tire inflation pressure
Engine compartment
· Change engine oil and filter
· Fluid level checks of the following:
· Engine cooling system, antifreeze and corrosion protection
· Windshield washer system
· Brake system
· Check and correct battery fluid level
· Check battery condition
· Check catch, safety catch and hinges on engine hood for proper operation
Trunk
· Correct tire inflation pressure in spare tire
B-Service — First visit at approximately 20,000 miles or one year after previous service, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Replace dust filter (not applicable to SL-Class)
· Replace combination filter (SL-Class)
· Check parking brake (function test only)
Wheels, brakes
· Check condition/thickness of front and rear brake discs
· Check front and rear brake pads for lining thickness
· Check tires for damage and condition
· Measure tread depth, record in mm
Underside of Vehicle
· Check for major components leakage
· Check for chafe marks, line routing, damaged components
· Check condition of front axle ball joints and rubber boots
· Check condition of mechanical steering components and rubber boots
Engine Compartment
· Check and replenish all fluid levels
· Check engine cooling system, antifreeze and corrosion protection
· Check brake system
· Check power steering
· Check Active Body Control
· Check windshield washer system
· Check condition of poly V-belt
Trunk
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Poll: mileage between oil change / brand of oil / DIY or dealer ?? Thanks! Rohf (Seattle) R170 SLK Class 27 08-05-2008 07:58 PM
c230 Kompressor B-serice DIY ??? spoons W203 C32 AMG, C55 AMG 2 11-10-2006 12:39 PM
Oil Change Questions... DIY Bryn3r General Mercedes-Benz 13 06-22-2006 11:44 AM
DIY Oil Change Questions from first timer RaleighMB W210 E-Class 4 02-21-2006 02:20 PM
need help!! has anyone chip their 2003 c230 kompressor? lorinser 69 General Mercedes-Benz 2 02-23-2004 01:25 AM
