» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 10-30-2006, 09:09 PM   #1 (permalink)
Date registered: Oct 2006
Vehicle: 2006 C230 Silver
Rear Speakers
I am interested in installing 2 additional rear speakers in my '06 C230WZ. I did not get the entertainment package with my car so I only have the default number of speakers (Front, and 2 Back Door Speakers). My question is, are the 2 rear back speakers pre-wired already? - So all I would have to do is just get a pair and install them and then I'm set? - Or is there more work than I thought will be required.
Much thanks in advance.
Ndrooo is offline   Reply With Quote
Old 10-31-2006, 05:38 PM   #2 (permalink)
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 05 C230WK-05 E320CDi
The speaker holes are back there filled with a foam pad. There is no wiring for speakers because the 320 watt digital amp that is part of the package along with its wire harness and the sub-woofer are not there.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline   Reply With Quote
Old 12-02-2006, 05:23 AM   #3 (permalink)
Date registered: Nov 2006
where is the amp i got the sub and disconnected it due to the fact that i installed 2 12 woofers.
tks
lodownlv is offline   Reply With Quote
Old 12-03-2006, 03:33 AM   #4 (permalink)
Vehicle: 2001 C320
Right side of trunk, behind the molding.
everycredit is offline   Reply With Quote
Rear Speakers! Darknessarises Audio & Telematics Forum 1 03-02-2006 12:31 PM
Rear Speakers Guest Audio & Telematics Forum 0 12-30-2005 06:19 PM
Rear Speakers Guest Audio & Telematics Forum 0 08-20-2005 05:12 PM
Speakers - Looking for rear speakers Pete1 W210 E-Class 6 03-29-2005 09:04 PM
