» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 08-29-2006, 12:35 PM   #1 (permalink)
Date registered: Aug 2006
BAS/ESP light in on when I push the brake pedal
Hello I have a problem with my Mercedes C200. When the engine is started the BAS/ESP light is off but when I push the brake pedal for the first time the light turns on and stays on until the engine is switched off.
When I switch on again and push the brake the light turns on again.
On advice I replaced the Brake pedal switch, but that did not help.
Does anyone know what causes this problem, and knows a solution?
Thanks in advance!
Best regards,
Cees
Cees is offline   Reply With Quote
Old 08-29-2006, 08:13 PM   #2 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
is it the brake warning light? or BAS/ESP warning message on the MFD?
Carlsson RS bodykit/Weltmeister Quad/equal length shorty headers/resonator delete/BBS RE 18x8 18x9/Evilsport ODPS/ECU/TEIN SS coilover/Brembo 355mm/AMG 330mm/eibach sways/05 grille/Bi-xenon/Comand/intake y-splitter/green filter/brabus steering wheel/LED mirror blinker/05+ taillight/Euro impact strip/Carlsson CF spoiler/black interior trims/Carlsson shift-knob/Carlsson pedals
to do list: 1. wash and detail car
FrankW is offline   Reply With Quote
Old 08-29-2006, 11:31 PM   #3 (permalink)
BAS/ESP light
Frank it is the Yellow BAS/ESP light that goes on on the MFD
Cees
Old 08-30-2006, 01:27 AM   #4 (permalink)
most likely wiring harness. have your dealer check it out. there's no diy fix on this.
Old 08-30-2006, 04:44 AM   #5 (permalink)
BAS/ESP light
The dealer didn't check and if there is ni good fix for myself I have to made a apointment with my dealer and let you know the results.
BAS/ESP Light on...Help! Marc W163 M-Class 22 05-06-2008 02:26 PM
Brake-light issue leading to BAS/ESP issue??? Isoplus R170 SLK Class 7 06-17-2006 12:57 PM
Dealer found cause of my "BAS/ESP" light coming on, and its not the brake lamp switch... S4toML W163 M-Class 7 07-14-2003 04:58 PM
BAS/ESP Light mlx52 W163 M-Class 9 04-29-2002 03:37 PM
BAS/ESP light sometimes goes on Guest (MBNZ) W202 C-Class 10 07-05-2001 10:48 AM
