Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 10-17-2005, 09:03 AM   #1 (permalink)
Date registered: Sep 2005
Vehicle: 2002 C240
Rear Door!
I noticed the other day that for no reason my rear passanger side door would not open from the outside, and that the door pin was out os the hole. The pin is no completely removed, and the door opens only from the inside. Is this something I can fix myself by takin the door apart, or should I take it to the shop? Thanks.
r23skyman is offline   Reply With Quote
Old 10-17-2005, 09:17 AM   #2 (permalink)
BF_JC230's Avatar
Date registered: Oct 2003
Vehicle: 1980 w123 230 "Sport", 2005 w203 230 Sport
Send a message via AIM to BF_JC230
RE: Rear Door!
so from what i gather in your write up...the door lock pin is missing and the door will not open...
sounds like some one unscrewed the pin or it fell off...
grab a long thin screw driver
a hooked screw driver
relocate the pin
and operate the remote lock until you can find the threaded rod lock in the door - move it into position for the hole - unlock the remote - moving pin up into hole, re thread the pin...
good luck
Jake
Do you enjoy wine?
http://www.myttv.com/Anne13059
BF_JC230 is offline   Reply With Quote
Old 10-17-2005, 09:33 AM   #3 (permalink)
mbenzoi's Avatar
Date registered: Oct 2005
RE: Rear Door!
what i'd do is to remove the panel for that door and investigate. i think its the easiest way to renew it. the pin just got loose on the connecting rod inside.
mbenzoi is offline   Reply With Quote
