Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 12-04-2004, 01:39 PM   #1 (permalink)
Date registered: Nov 2004
Vehicle: My Benz: 04 S430
GPS Antenna
I decided to mount the Factory antenna my window and loose the Hidden antenna for my command so that I will have that "OEM" look.
Anyone had this antenna mounted after the fact??
Or any suggestions?
I plan on getting my dealer to do the install for me unless they are outrageous,otherwise I will have Custom sounds or somebody mount the antenna for me in the window I knw there is some drilling involved, so I want it done correctly.
Thanks..
My04230k is offline   Reply With Quote
Old 12-04-2004, 02:15 PM   #2 (permalink)
paulhdick's Avatar
Vehicle: 2001 ML-320, C-320
RE: GPS Antenna
I think I just answered your e-mail as well ...
The antenna mounted on the outside center of the rear window is not the NAV antenna. It is the phone antenna, and it is not drilled either, it just gets stuck on. The "connection" for it is a proximity RF grid through the glass so no hole is required. The GPS antenna mounts under the right top rear window and is a flat approx 1"x2" stick on .....
Paul
01 ML-320 -- M1 Luxury Package, M2 Convenience Package, BoseĀ® Premium Audio w/integrated 6-disc CD-changer and Bose sail-panel tweeter add-on, OEM 3rd Row Seat Package, OEM DVD navigation, OEM MB V60 integrated cell phone upgraded to a non-Mercedes Motorola V551 using the Mix-Box 100 Interface, Voice Control, OEM vehicle entertainment system with OEM VCP, OEM DVD player, and OEM wireless headphones, OEM Style 1 chrome brushguard with skidplate, OEM Style 1 chrome sidesteps, OEM fender flares, OEM rear mudflaps, OEM PIAA (959) fog lamps & matching H3 PIAA Crystal-Ion integrated fog beams, OEM trailer hitch with (modified) Bully stainless steel hitch step, Schatz oval exhaust tip, Schatz chrome a/c rings, OEM AMG chrome cluster rings, and some esoteric stuff you will probably never notice ... but I know it's there.
paulhdick is offline   Reply With Quote
