w202 c220 key broken off in ignition lock - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-29-2010, 03:01 PM Thread Starter
Date registered: Nov 2009
Vehicle: 1994 and 1995 C220 and a 2000 ML320
Question w202 c220 key broken off in ignition lock
I have read the threads on other mercedes lock removel and was wondering if someone knew the best way to remove the lock out of a 1995 C220 with the key broken off in the lock. I have not been able to remove the key it is to deep in the lock. I have the bottom half of the dash removed the instrument cluster loose and ready to be pulled out as soon as I pull the steering wheel off. W202
Redmanrh is offline
post #2 of 6 (permalink) Old 08-16-2010, 10:27 PM
Date registered: Aug 2010
Vehicle: C 220
Hi !
I have a 1995 sedan, C220. Ign key won't turn.
Tried to unjam the lock (tumbler)
I'm looking for step-by-step instructions for removing the dash panels, Ign lock housing
solanusa is offline
post #3 of 6 (permalink) Old 08-17-2010, 01:01 AM Thread Starter
Smile 95 mercedes tumbler
What have you done to try to get the key to rotate the tumbler.
I can help you. if you can get the tumbler in to the 1 position it will save you about $200.00
If you do what I have done it will cost you about $300.00 in parts. (NEW)
Less if you find used parts.
Redmanrh is offline
post #4 of 6 (permalink) Old 08-19-2010, 08:39 AM
Vehicle: C 220
Post c220 ignition key won't turn at all, to start car
Redmanrh;
The car is on level ground, in driveway.
Parked the car and the next day the key will not turn at all.
Doors unlock to get in car
Tried many things to free up the key, incl
-turning the steering wheel
-spray "wd40" lubricant in tumbler
Key does not move to any position.
I have just bought a used ig lock housing, w/ key ( $93) to replace the whole unit. I'm now searching for r/r instructions
thanks
solanusa is offline
post #5 of 6 (permalink) Old 08-20-2010, 05:22 AM Thread Starter
Smile
I have never done this, but there were some having talk about putting a vibrating sander or another vibrating device on the key and trying to turn the key..????????
To do what I have done you are going to need some tools.
Torx socket set (two needed I will get the sizes)
Torx screw driver set (one size needed)
DASHBOARD SERVICE KIT or INSTRUMENT CLUSTER RADIO IGNITION PULL TOOL (same thing different name) found on eBay.
Ignition Lock Collar Tumbler Removal Tool. Found on eBay
10 mm Allen wrench.
Die grinder (I used air grinder).
About 10 to 12 medium to small pointed grinding stones.
13 mm open box end wrench
Small and medium Philips screw driver
I will be posting more information for you when I collect it.
Red
Redmanrh is offline
post #6 of 6 (permalink) Old 08-20-2010, 01:57 PM
Vehicle: C 220
Post thnx
thankx
10 mm Allen wrench.
Red
solanusa is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W202 C36 AMG, C43 AMG
    C220 key broke in ingition lock Redmanrh General Mercedes-Benz 8 03-23-2012 10:43 PM
    Broken key in the ignition... HELP! Holshot W126 S,SE,SEC,SEL,SD,SDL Class 12 08-08-2009 09:56 PM
    Broken Ignition Lock 1990 300e (Weird problem) itsandymann W124 E,CE,D,TD Class 0 05-09-2009 10:59 PM
    Ignition Wire Set C220 W202 1994 Engine 111 rmt6668 W202 C-Class 0 12-19-2007 08:14 AM
    Broken Ignition cylinder, Cant turn key, Any Help??? Sandro N W210 E-Class 1 02-05-2006 01:13 PM
