How to tighten/quicken up my steering response - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-17-2010, 12:07 PM Thread Starter
Date registered: Nov 2009
Vehicle: 1998 C43 AMG
Anyone have any suggestions?
I took it out into the mountains the other day and was wishing for faster steering response, tighter steering response.
I felt like it was quite a chore to get it around some of the turns. Although I'm a bit biased because at the track I drive an S2000, so maybe it was just my imagination/me being overly demanding of my C43.
But I was just wondering if there are any modifications that I can do. I see that people replace their steering bushing, so I figured I'd ask.
Any input or help is appreciated.
TunerPlayground is offline
post #2 of 6 (permalink) Old 03-17-2010, 07:09 PM
thepinoc's Avatar
Date registered: Oct 2008
Vehicle: 98c230 & 98c43
get a smaller steering wheel, that's where it begins! lol
thepinoc is offline
post #3 of 6 (permalink) Old 03-17-2010, 11:07 PM
eundaddy's Avatar
Date registered: Aug 2009
Vehicle: 1998 C43
Send a message via AIM to eundaddy
i changed my steering fluid and it made steering tighter
eundaddy is offline
post #4 of 6 (permalink) Old 03-17-2010, 11:18 PM
Date registered: Mar 2010
try pressure testing your power steering pump pressure, your 43 should have a tight steering response, see if your front lower control arm bushings are cracked, also stiffin up the suspesion"new h&r - renntech - racing springs. can't remember does you 43 have a 119 or 113 engine i know some early 98's had the 119 if it's that check your steering gear box they can be tightned up
themadbenzer is offline
post #5 of 6 (permalink) Old 03-18-2010, 06:34 AM
jayrash's Avatar
Date registered: Mar 2009
Vehicle: 1995 C 36 AMG; 1992 W124 300E (M103 Ex Mosselman TT KIT) was 320hp @10psi now stock :(
i reallly reallly doubt that any W202 came from factory with the M119. Thou yes a few W202s tuned by Brabus, Kleeman, REN did shoehorn the M119 into the tiny W202 front end.
Jay,
-1995 Blue W202 C36 AMG (M)
-1995 Black W140 S500 (Lady)
-1992 Black W124 E300 (Dima) (Ex-Mosselman
Twin turbo Kit).
-1988 Black W124 300 E 4-Matic.(Nadeen)
-1983 Brown W126 500SEL.(Old Lady) (Sold)
-1981 Gold W123 280CE.(Dareen) (Sold)
http://www.youtube.com/user/jayrasheed
jayrash is offline
post #6 of 6 (permalink) Old 03-19-2010, 09:28 AM Thread Starter
hmm. ill look into my bushings, and also about changing my steering fluid.
what kind of difference does changing the steering damper make on our car?
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W202 C36 AMG, C43 AMG
    After you remove steering wheel, how do you tighten combination switch NCJETSKIER W210 E-Class 2 07-29-2007 12:19 PM
    Tighten Steering in SL600 diarmuid R129 SL-Class 7 04-20-2007 07:44 PM
    Power Steering leak - Where to Tighten? davidby R129 SL-Class 9 01-26-2007 04:24 PM
    '85 190D: Can i tighten up the play in the steering? 3030vision W201 190-Class 1 12-23-2004 04:02 PM
    How to tighten up Steering Box on a W124 300CE 850R W124 E,CE,D,TD Class 2 10-31-2002 08:46 PM
