» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz AMG Forums > W202 C36 AMG, C43 AMG
Old 07-05-2007, 06:02 PM   #1 (permalink)
Date registered: May 2003
Vehicle: C43, E55, CLK55, G55
Power Steering Fluid Leak
I was stuck on I5 because the power steering pulley broke in the middle and belt came loose. The pulley was from EVO sports. Anyhow, I had the old pullies installed, but when I got home, I noticed a puddle of power steering fluid on the floor. I found that the leak is between the reservoir and power steering pump. I think the mechanic pulled the 2 apart and did not put the gasket on correctly.
Anyone ever had this problem?
fastneutron is offline   Reply With Quote
Power steering Fluid Leak? indpndntrd W163 M-Class 2 06-29-2007 05:44 PM
Transmission Fluid in the Power Steering Fluid reservoir ldshull Vintage Mercedes-Benz 4 06-12-2006 10:59 AM
Colour of power steering fluid after p/s fluid & filter change -- normal? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 14 05-03-2006 08:12 AM
power steering fluid leak jas322 W201 190E, D-Class 3 03-28-2006 03:28 AM
Power Steering Fluid Leak BenzRider2001 W163 M-Class 1 03-26-2005 11:59 AM
