Hi,
so today i was messing around with my fuses trying to fix some stuff. I started the car and everything was ok, then turned it off (didnt drive it). After Little fiddling with the fuses the bas esp and abs light came on. I called Mercedes and they said it isn't a fuse problem, but i didn't even drive the car before the lights came on. He said one of my tires thinks its sliding. I think its a fuse problem (that i caused) any ideas as to what it could be and how i can fix it? I checked over all the fuses i messed with but nothing. Any help would be appreciated.
Thanks
double check the fuses you try to fix, there might be some loose connection or a bad fuse that you over look, otherwise it's your brake lamp switch, around $15.00 and it's a DIY job..do a serach you'll find it.
