» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 06-02-2003, 07:17 PM   #1 (permalink)
Date registered: May 2003
Vehicle: 1996 C220/ 1999 ML 320
trans fluid
I want to change my trans fluid on my 11/95 C220 but i dont know what fuid to use. I called the dealer and they told me just use regular Dexron III trans fluid. I called a local shop and they told me only use Mercedes Benz fluid that cost $9.00 each. Then i called another shop and they told me that only 97s with electronic trans uses the Merceds Benz fluid. And the 95s uses regular trans fluid. I check the dip stick and the fluid is clear not red like the Dexron III. Pls help. Thanks.
Mark[:D]
benzmark23 is offline   Reply With Quote
Old 06-03-2003, 04:54 AM   #2 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
I think newer MB's use MB trans. fluid. Yours should use DEXRONIII. I use Mobil 1 (synthet...
I think newer MB's use MB trans. fluid. Yours should use DEXRONIII. I use Mobil 1 (synthetic) tranny fluid with great results on my '94 C280. It should work for you as well.
Sergio
'95 E320 SE
'99 ML430 (gone)
'01 E320 Wagon 4-Matic
'94 C280 (R.I.P)
Sergio is offline   Reply With Quote
Old 06-04-2003, 01:26 AM   #3 (permalink)
scorchie's Avatar
Vehicle: CLK55/G500/E55/ML55/etc.
Re: trans fluid
Mark[:D]
Actually, the MB fluid is used in 1997 and later C-class (and start at different years for different models).
Your transmission should be fine with Dexron III, however it really doesn't hurt to look at your OWNER'S MANUAL to see what it says.
-s-
1987 190E / 1987 300E x2/ 2001 CLK55 / 2001 ML55 / 2002 G500 / 2003 E55 / 2006 R350 / 2006 G450 / 2007 sumtin sumtin
scorchie is offline   Reply With Quote
Old 06-23-2003, 11:39 PM   #4 (permalink)
Date registered: Jun 2003
Vehicle: 95 c220
I have the same car which I recently bought. Where is the dip stick and also how do you...
I have the same car which I recently bought. Where is the dip stick and also how do you check the power steering fluid?
tquiambao is offline   Reply With Quote
