Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 01-20-2003, 04:25 AM   #1 (permalink)
Date registered: Jan 2003
the best spark plugs for my 1994 C280
hi!! i'm aroppi from Hong Kong and i'm using a 1994 C280 with straight 6 engine. it's really a great car and my dad likes it very much also!!!
i'm going to change the spark plugs for it and wanna try other brands beside the original parts.
any suggestion?? Thanks!!!
aroppi is offline   Reply With Quote
Old 01-20-2003, 10:02 AM   #2 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
Use the same exact plugs that the car came with (BOSCH). Do not try the titanium; use copp...
Use the same exact plugs that the car came with (BOSCH). Do not try the titanium; use copper plugs only.
Sergio
'95 E320 SE
'99 ML430 (gone)
'01 E320 Wagon 4-Matic
'94 C280 (R.I.P)
Sergio is offline   Reply With Quote
Old 01-20-2003, 10:26 AM   #3 (permalink)
thanks for the reply!! but... why?? how about those called iridium spark plugs?? seems t...
seems that the iridium plugs are the "longest life" one!!!
Old 01-21-2003, 10:56 AM   #4 (permalink)
Sergio's Avatar
Vehicle: 1995 E320
Modern MB engines can use titanium plugs. Older ones (don't remember how old but '94 quali...
Modern MB engines can use titanium plugs. Older ones (don't remember how old but '94 qualifies as older) cannot. I can't remember why and I wish a had a logical explanation BUT someone with greater mechanical knowledge explained this to me and I corroborated it with MB service department. It's not worth risking damage to your engine.
As far as longer life, if you replace your plugs every 30-50K miles or so, that should be OK.
Last time I did, I paid $1.63 per plug and it took less than an hour (well worth the small investment).
Old 01-21-2003, 11:01 AM   #5 (permalink)
Sergio's Avatar
Vehicle: 1995 E320
Old 01-22-2003, 04:44 AM   #6 (permalink)
got it!!! thanks for your advise!!! by the way, i found that my C280 has a kind of "flo...
by the way, i found that my C280 has a kind of "floating" idling rpm when i slow down the speed from driving. say, from fast road to junction. once i slow it down by pressing the brake, the rpm will drop smoothly but once it reach the idling rpm, it starts to "float" +/- 300rpm!!!?
well, any idea about this??
Old 01-22-2003, 06:45 PM   #7 (permalink)
Vehicle: 1993 300E 3.2
Sounds like a vacum leak or a defective MAS sensor. ...
1993 300E 3.2
-Rebadged as an E320 to correct Mercedes' mistake on all 300E 3.2's misbadged as a 300E.
- Smoke Silver / Parchment
- O.E.M. 1995, 15" Polished 8-hole rims
- O.E. Bosch Euro Headlights
- O.E.M. 94-95 clear / yellow front corners
- S-class wood / leather shift knob
- SLK chrome shift surround
suginami is offline   Reply With Quote
Old 01-22-2003, 07:34 PM   #8 (permalink)
Vehicle: S320W
I had this problem when i had a c280, had to change the spark plugs plus the ingnition coi...
I had this problem when i had a c280, had to change the spark plugs plus the ingnition coils.
Very big car, with a very small engine.
///S320 is offline   Reply With Quote
Old 01-22-2003, 08:05 PM   #9 (permalink)
Once again, Thanks SO much for the replies!!! well, let me say something more... i fou...
i found that once the idling rpm starts to "float", i press the gas pedal again, then the idling rpm will go up then stop for a second on @1000rpm then drop smoothly to the idling rpm. if not, the rpm will still "float".
by the way, what is MAS sensor??
P.S. i've changed the spark plugs to the original parts yesterday and i've changed the ingnition coils 6 months before.
Old 01-22-2003, 09:40 PM   #10 (permalink)
I'm assuming MAS meter is the Air Mass Meter. I had to change that on my 1999 C280 to g...
I'm assuming MAS meter is the Air Mass Meter. I had to change that on my 1999 C280 to get the engine light to go off as the Oxygen sensor was detecting that my mixture was running lean.
The part is on www.bimmerzone.com for $196.26. Look in section of air intake. This is cheapest place you'll find it... trust me on that!
Good Luck,
timecop369
timecop369 is offline   Reply With Quote
