Next week, I want to change the oil/oil filter, spark plugs, clean the throttle body, and run a can of seafoam through her. Is that too much for one day. Which one do you suggest I do first, which one last? Also, is torquing down the spark plugs necessary? I also have read online that sometimes after cleaning the throttle body, the car is hard to start. Should I look forward to that on this model? And as far as the throttle body is concerned, how do I clean it without removing it since its vertically mounted and the gunk won't fall straight out? And one more question, is running a can of Lucas fuel cleaner through the tank recommended after all of this.
