Hi everyone,
I've searched threads for the last 2 weeks (even on other sites) for find a solution to my problem. Here is are my symtoms: When the car is off and the key not inserted, my ac/heater blower keeps running. Here is what I've done so far to resolve this problem:
1. Replaced the blower - still runs
2. Replaced the regulator or resistor (everyone calls this differently) - still runs.
3. Replaced the regulator or resistor agian (thought I might have purchased a faulty one) - still runs.
4. Reset the computer by disconnecting the battery - still runs.
5. Removed and disconnected the dash climate control unit - still runs.
Pretty much all the threads I've read points to the regulator that is screwed to the blower unit but my problem isn't going away. I figured if I would disconnect the climate control unit, the blower would at least stop but that wasn't the case. Obviously the regulator is drawing power directly from something, but I don't know what. For now I'm just unplugging the blower. The fuse is fine. My question is; if the blower, regulator and climate control unit is working properly, what could be causing the blower to contiously run? Is there something else that the fuse wire runs to before the regulator? Does the fuse wire run to the climate control unit then to the resistor? If so, then my car is haunted! Please help!
