Vacuum Fuel Tank - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-16-2013, 09:22 AM Thread Starter
Date registered: Jul 2013
Vehicle: Mercedes C200 CDI W202
Vacuum Fuel Tank
Hello,
I have a lot of vacuum when I open the fuel cap. I know there is normaly an overpressure but in this case there is a very high vacuum, also a dent in the fueltank an dissapeares when i open the fuel cap.
A strange thing is that I discovered a lot of small pieces of plastic (grains) in the fuel filter when i changed it. I really dont know where they come from. And whats the name of the sparepart (see attachement).
Someone a solution for this problem?
Mercedes c200 CDI (2000)
Engine M611.960
Thanks,
jawzay is offline
post #2 of 5 (permalink) Old 07-16-2013, 08:02 PM
Date registered: Jul 2007
These cars always run with a vacuum on the tank, just not a lot of vacuum. Certainly not enough to collapse the tank.
When the car is shut off, the system is closed and there is a slight pressure buildup, and the fumes are supposedly absorbed by the charcoal cannister.
There is an electrical valve that switches the system, and it's probably this valve that is not working.
I never had to fix it, and I can't tell you where it is. Maybe someone else can.
There is a electronic
marvinstockman is offline
post #3 of 5 (permalink) Old 07-17-2013, 06:04 AM Thread Starter
Thanks,
As a temporary solution I dont turn the fuel cap to close it, so the system can bleed.
Hope someone knows the problem and the solution.
jawzay is offline
post #4 of 5 (permalink) Old 07-17-2013, 02:20 PM
melk81's Avatar
Date registered: Feb 2013
Vehicle: 1994 E320
Quoted: 7 Post(s)
Send a message via Skype™ to melk81
No CEL?
The purge solenoid is right next to the brake hydraulic pump.
melk81 is offline
post #5 of 5 (permalink) Old 07-18-2013, 05:20 PM Thread Starter
Whats a CEL? And right under the fueltank there's an electric valve (see pic). Whats the function of this valve and whats its name?
jawzay is offline
