98 c230 center vent eradic - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 12-16-2012, 06:59 AM Thread Starter
Date registered: Jan 2010
Vehicle: 1998 c230
wondering why center vent comes and goes mostly gone now only end vents working ?
Towey is offline
post #2 of 12 (permalink) Old 12-16-2012, 02:48 PM
Aquinob's Avatar
Date registered: Jul 2012
Vehicle: 2010 E350, 2005 Tundra Sold the 1998 C230
Quoted: 30 Post(s)
It probably changes due to engine speed and whether you are accelerating or not. All your dash vent doors are controlled by the vacuum system and the bellows leak over time. As the vacuum changes with the engine, the doors open and close on their own. Take a looksee here to see what it would take to fix them: Link to dash teardown Mine does the same, have yet to muster the courage to tear the dash apart to fix it.
Aquinob is offline
post #3 of 12 (permalink) Old 12-16-2012, 03:15 PM Thread Starter
Vehicle: 1998 c230
Yeah Thanks,I wonder how to prove it is a leak at bellows or at a line connector ? before it routs under dash I would think a leak anywhere in that line would cause the same symptom before tearing out dash.Any thoughts ?
Towey is offline
post #4 of 12 (permalink) Old 12-16-2012, 05:09 PM
Date registered: Feb 2011
Vehicle: 2000 C230 Kompressor Special Edition
Quoted: 15 Post(s)
C230's with the manual/rotary dial system do not have the bellows like the cars with the automatic push button type system. The rotary dial for vent selection manually moves the levers that open/close the vents.
What type of system does your car have?
Mercedes-Benz - Engineered like no other car in the world.
bachusattackus is offline
post #5 of 12 (permalink) Old 12-17-2012, 07:22 AM Thread Starter
Vehicle: 1998 c230
Automatic climate control
Towey is offline
post #6 of 12 (permalink) Old 12-17-2012, 07:57 PM
rudedude's Avatar
Date registered: Jul 2005
Vehicle: ML320,C230, F250, Bayliner, Mountain Bike, Fleetwood Motorhome etc...
You most likely have a vacuum leak in the engine bay. that is the same thing that happened to mine. I had to replace a few vacuum lines that were cracked.
True success is being the master of your own time.
rudedude is offline
post #7 of 12 (permalink) Old 12-18-2012, 10:44 AM Thread Starter
Vehicle: 1998 c230
That makes sense.Thanks
Towey is offline
post #8 of 12 (permalink) Old 12-18-2012, 01:24 PM
EightPM's Avatar
Date registered: Apr 2012
Vehicle: '91 M1A1 Abram's Tank
Quoted: 55 Post(s)
If you pull apart the cover inside the right hand side of the trunk there is a vacuum box. I found a few disconnected hoses and it fixed the problem. It also made my rear head rests go down.
"Insert witty quote here "
EightPM is offline
post #9 of 12 (permalink) Old 12-18-2012, 05:09 PM Thread Starter
Vehicle: 1998 c230
Thank you also,more great information.So much for Christmas shopping,Saturday will be spent tracing vacumn lines under hood and in the trunk.Thank you both Ill let you know what I find.Tow
Towey is offline
post #10 of 12 (permalink) Old 12-18-2012, 06:23 PM
rudedude's Avatar
There is also a vacuum resivoir in the right front fender well. To access you have to remove the wheel then the inner fender plastic liner.
rudedude is offline
