Possible mount failure? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 11-18-2012, 08:18 PM   #1 (permalink)
Date registered: Dec 2011
Unhappy Possible mount failure?
So I will try to describe this the best I can.
I think I might need new motor/transmission mounts.
I have a 99 c230K.
When the engine is cold, I start the car it starts up a little rough - probably just because everything's kicking in at once, and then as usual it settles down rather quick. - so that seems normal. My problem is though, one these cold starts if I leave my car in 'P' or "N' - it is fine; but if I put it in 'D' and sit on the brake (not moving) it shakes vigorously (putting it in 'R', it only shakes a little). After driving the car up to operating temp, the shaking completely goes away when stopped and still in D.
So would bad motor mounts only affect this? if not, what else do you think it could be??
Thanks in advance
PumaRun12 is offline   Reply With Quote
Old 11-18-2012, 10:03 PM   #2 (permalink)
jc1kz's Avatar
Date registered: May 2012
Vehicle: 94 Midnight Blue MB C280 w/131000 miles
Here is a video from you tube to see if it is the motor mounts...
jc1kz is offline   Reply With Quote
Old 11-19-2012, 05:53 AM   #3 (permalink)
alright, I tested that this morning, and there was slight movement, nothing really dramatic.
So I guess I can change them, I just didn't understand why it only vibrates when its cold, no other time.
My car is due for a fuel filter and a complete oil change - possibly doing a coolant flush too, in the next few days, maybe that will help?
Old 11-19-2012, 08:25 AM   #4 (permalink)
Date registered: Sep 2005
Vehicle: 1999 C280, 2000 C280, 2000 C230K
How many miles on this set of mounts? Were they OEM or some other brand?
I would think the vibration from bad motor mounts is continuous regardless of engine hot or cold. Not noticeable at speed but most obvious you are at a stop. For me it was most noticeable when doing slow speed maneuvers like parallel parking.
glenmore
1999, 2000 C280
2000 C230K
glenmore is offline   Reply With Quote
Old 11-19-2012, 08:35 AM   #5 (permalink)
I am not sure if they are OEM or what...
The car has 150k on it, and it was serviced fully by a MB dealer until 125k...
And that is what I was thinking, so I couldn't understand why it only happened when cold. Would the same go for the Tranny Mount too?
Old 11-19-2012, 12:30 PM   #6 (permalink)
Only guessing, but in 125K, mounts were probably done once at the dealer with a hi-quality OEM part.
You can just take a look at the tranny mount to see if it is broken or really smooshed. It is readily visible.
Old 11-19-2012, 02:28 PM   #7 (permalink)
oberoi's Avatar
Date registered: Mar 2006
Vehicle: W203-C180 SLK230/C180/230E/280SE
Tranny mount can look good and still be crap - Replace anyway along with motor mounts
Oberoi
oberoi is offline   Reply With Quote
Old 11-19-2012, 03:45 PM   #8 (permalink)
Triggerhappy's Avatar
Date registered: Nov 2009
Vehicle: 1997 C280
The motor mounts probably need to be replaced at 150k (if they weren't replaced by Mercedes at 100k) but this does not sound like a motor mount problem.
Triggerhappy is online now   Reply With Quote
Bookmarks
