I got tired of the hesitation on acceleration sometimes so finally decided to tackle the throttle actuator. I should have done it when I redid the engine/trans wiring harness last winter, but I didn't realize that this deteriorated too.
The throttle actuator comes out very easily. Take the air intake off, then the intake air splitter valve. Then the rubber intake tube, 4 allen head screws, remove the connector to the throttle linkage and it will come off.
The more I dug in, the more I was amazed that the car ran. I was trying to check continuity between the pin ands and the circuit board end and just stopped because they were all shorted together! I soldered in new wire and got it all wrapped up last night. Only thing left to do is use some silicone sealer at the throttle body hole and then put it back on and test.
I have all the old wires and was seriously thinking about sending them to Mercedes. I am impressed that the car ran with the deteriorated engine harness and throttle actuator harness. Mercedes must have done a lot of research on the control units to deal with intermittent shorts and bad values. Start to finish was about 5 hours for the rewiring part
