M111 Oil Separator Replacement - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W202 C-Class
Old 09-19-2012, 08:19 PM   #1 (permalink)
Date registered: Feb 2011
Vehicle: 2000 C230 Kompressor Special Edition
I am posting to let people know of the positive results on changing my oil separator. The oil separator is the black box attached to the top of the motor. It has three hoses that go in/out. It can be clogged with oil and varnish over the years, and therefore may not breath or flow air as well.
My car is a 2000, and the hoses were very brittle. They were hardened to the point of cracking, and immediately cracked when I tried to remove them. Be careful not to let any bit of cracked hose enter the valve cover breather hole!
I ordered the parts from parts dot com, including a new separator. Cleaning the seperate would have taken time, chemicals, and would have produced chemical waste, so I just bought a new one. It's about $29.00 on parts dot com. The hoses are dealer items as well. Since the hoses will break when you take them off (99% chance of breaking), you shouldn't start this job without them.
There are only two bolts that take a #30 Torx, use some blue loctite when you reinstall. The job is easy.
The result was a smoother engine. It was obvious from the start. Idle is better, and there is better response throughout the entire rev range. Once again, the improved engine performance also has translated into improved transmission functioning. Total cost was about $86, including shipping.
Anyone with an M111 should do this. These hoses are beginning to dry-rot anyway, and the oil separator can rob you of performance. There are some posts from people who have used chemicals to try to soak out the gunk inside it, but buying a new one is a sure fire way to get the upper engine breather system back to factory-new specs.
Mercedes-Benz - Engineered like no other car in the world.
bachusattackus is offline   Reply With Quote
Old 09-20-2012, 10:35 AM   #2 (permalink)
The part numbers for the job:
111 018 3182 - hose
111 018 1682 - hose
111 018 1882 - hose
111 018 0335 - oil separator
This is for the the 2000 C230 Kompressor, please check with EPC or with your dealer for any other models.
(I noticed again how well it drove this morning. If you haven't replaced, or completely cleaned out your oil separator yet, DO IT!)
Old 09-21-2012, 08:10 PM   #3 (permalink)
Wow. It's like a different engine. There is more power in the mid-range, and the dead spots I used to experience while accelerating are gone. Such a simple job for so much benefit- I wonder how many M111 owners are overlooking this easy but necessary maintenance item.
I've looked for cheap performance upgrades for months and never knew how much I could gain from putting in a new oil separator.
Old 09-23-2012, 10:16 PM   #4 (permalink)
Date registered: Sep 2011
Vehicle: 1999 C230K Sport
this is a very informative post. thank you very much and I will be doing this to my 1999 C230K as well. i'll let you know how it works out for me.
How do I prevent any rubber pieces from falling inside the valve cover breather hole? Do I just slowly pull off the hoses to prevent them cracking?
Olly84 is offline   Reply With Quote
Old 09-24-2012, 04:00 AM   #5 (permalink)
Just be alert. I used needle nose pliers to peel away the tube. The old tube practically disintegrated.
Driving on the interstate I punched it yesterday, the car kicked down two gears and started to accelerate. I could hear the supercharger whining. Brought a big smile to my face. You are going to enjoy the result!
Old 10-04-2012, 03:19 AM   #6 (permalink)
just replaced mine. Idle is the same, but upon heavy acceleration the engine does seem to rev up more quickly and freely. Easy thing to change!
Old 01-24-2013, 08:04 PM   #7 (permalink)
Date registered: Nov 2010
Did you guys access the oil separator from the top. Anything needs to be removed to get to it?
Russmb is offline   Reply With Quote
Old 01-25-2013, 09:53 PM   #8 (permalink)
What car do you have. On the M111 the oil separator just bolts right to the valve cover. You don't have to remove anything.
http://www.benzworld.org/forums/r170...separator.html
Old 01-26-2013, 07:02 AM   #9 (permalink)
It's ML350 2008. If I remove air filter housing/engine cover will I be able to get to it and replace from the top?
Bookmarks
