97 c280 in limp/home mode help - Mercedes-Benz Forum
post #1 of 38 (permalink) Old 06-07-2012, 08:05 PM Thread Starter
Date registered: Jun 2012
Vehicle: 97 c280
whats up MB ppl im new here....and i am having this issue where the car starts up fine but the ets light is on and when i put it in gear it seems to slam in to 1st gear and reverse....ill try to drive it but it wont shift out of 1st....but if i put the can in d-2 it will shift from 1st to 2nd with no problems shifts smooth....NO CHECK ENGINE LIGHTS ON....no lights on at all on the cluster except the ETS light....i got the car not running....so i did a lil bit of work and got it running and here are some of the things i have done i did a drain and fill on the trans what came out i put the same amount back it.. ive cleaned the mass are flow... new plugs... new motor oil...replaced one coil...CAN SOMEONE HELP ME PLZZZ!!!!!!!!!!!!!!
eddie g is offline
post #2 of 38 (permalink) Old 06-08-2012, 12:28 AM
FAR888's Avatar
Date registered: Mar 2007
Vehicle: 2002 ML55 AMG, 2005 Chrysler Crossfire Coupe Limited, 1999 C280
I know you said there is no check engine light but I'd still get it scanned for OBDII codes.
Sent from my Samsung Galaxy Note using AutoGuide.com
FAR888 is offline
post #3 of 38 (permalink) Old 06-08-2012, 06:44 AM Thread Starter
Vehicle: 97 c280
I have an obd2 scanner alreddy
eddie g is offline
post #4 of 38 (permalink) Old 06-08-2012, 07:18 AM
rjb190e's Avatar
Date registered: Apr 2006
Vehicle: 2.3-16 | A3 2.0T | 986 Boxster
Quoted: 14 Post(s)
Send a message via AIM to rjb190e Send a message via Yahoo to rjb190e
There's some sensors that will trigger that light. Speed sensor and stop light sensor come to mind. The speed sensor will probably cause erratic shifting or trigger limp mode. Try and disconnect the battery and see if the sensor resets itself (if thats the problem).
rjb190e is offline
post #5 of 38 (permalink) Old 06-08-2012, 07:26 AM Thread Starter
Vehicle: 97 c280
I tried disconnecting the battery for 3 days light still comes on right after i start the car I don't even get the chance to put it in gear before the light comes on
eddie g is offline
post #6 of 38 (permalink) Old 06-08-2012, 07:53 AM
rjb190e's Avatar
Quoted: 14 Post(s)
Because there's no CEL, I'd bet on a transmission sensor /speed sensor related problem. You won't be able to diagnose those with an OBD2 scanner.
If you've checked the transmission fluid level, have a happy CEL free engine, the next thing to check would be the transmission conductor plate and the speed sensor at the rear differential.
rjb190e is offline
post #7 of 38 (permalink) Old 06-08-2012, 07:56 AM Thread Starter
Vehicle: 97 c280
where is the conductor plate located
eddie g is offline
post #8 of 38 (permalink) Old 06-08-2012, 08:10 AM
rjb190e's Avatar
Quoted: 14 Post(s)
Here's a link to the 210 board detailing how to replace the conductor plate. It's for the 5G-TRONIC transmission (which you should have with a 1997)
http://www.benzworld.org/forums/w210...ml#post3538903
There's a PDF to download that has a step by step DIY (including symptoms leading up to replacement).
rjb190e is offline
post #9 of 38 (permalink) Old 06-08-2012, 08:48 AM Thread Starter
Vehicle: 97 c280
that's for a 99 E 320 i have a 97 c280 or are the trans the same
eddie g is offline
post #10 of 38 (permalink) Old 06-08-2012, 09:06 AM
rjb190e's Avatar
Quoted: 14 Post(s)
They are.
rjb190e is offline
