Transmission doesn't shift gears - 1st gear working only and Reverse - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-27-2012, 09:55 AM Thread Starter
Date registered: Oct 2007
Vehicle: 1999 C43 AMG
Send a message via Yahoo to mercedesc230
Unhappy Transmission doesn't shift gears - 1st gear working only and Reverse
Hello Benz lovers!
My transmission doesn't shift gears anymore .
A couple days ago, I was making a right at a stop sign and I manual put into 4-3-2-1 (i was an idiot, i don't know what i was thinking - "to get more power" and launch fast, duh! )
A couple seconds later, I think, I noticed that would not shift.
Pull over, stop the car, try again nothing, i tried manual shifting-nothing, disconnect minus at the battery, wait 5 min, same. Would only work in reverse and Drive - in 1st gear.
A friend checked the codes for me:
P0715 - turbine input shaft speed sensor circuit
P0720 - shaft speed sensor circuit
I have a car for more than 5 years and I hate to see it gone.
A local shop specialized in transmissions for German cars said $1700 to fix it with 6 months warranty . I live in South Florida.
Car is a 1997 C230 with 233K miles (5 speed automatic).
Any advice is appreciated
mercedesc230 is offline
post #2 of 5 (permalink) Old 02-27-2012, 10:59 AM
rudedude's Avatar
Date registered: Jul 2005
Vehicle: ML320,C230, F250, Bayliner, Mountain Bike, Fleetwood Motorhome etc...
First you're not an idiot for down shifting your car. If you weren't supposed to do it there would only be a "D" position for drive and not 1234&D...
There seems to be a defect in the 1997-1998 transmissions. Mine did the something similar. It cost almost 3 grand to fix a few years ago. You need to evaluate the car and your attachement to the car and decide if it's worth it to you to fix. Personally if the car is in good condition I would get it fixed. Much better than a car payment. Also when you get it fixed make sure they are going to do all the updates that will fix the flaw and make it much more durable and responsive in the shifts...
True success is being the master of your own time.
rudedude is offline
post #3 of 5 (permalink) Old 02-27-2012, 12:58 PM Thread Starter
I found this thread in the W140 section:http://www.benzworld.org/forums/w140...r-contact.html
There, the op said:
conductor plate-$170, 13 pin connector-$9, valve body spring-$3.52, tranny pan gasket/filter-$15. Also added 4qts of Mobil 1 synthetic ATF!
I am wondering if the parts are same for w202.
post #4 of 5 (permalink) Old 02-27-2012, 04:14 PM
rudedude's Avatar
Could be the same transmission. My ML320 has the same one
rudedude is offline
post #5 of 5 (permalink) Old 03-01-2012, 03:39 PM Thread Starter
The parts are the same.
Could anyone tell me what transmission fluid to buy instead of the one at the dealership that cost $20/qt? I need to buy 8L , right ?
No forward or reverse gear.......Engages gears fine........ Help! J4GG4 General Mercedes-Benz 1 05-08-2011 10:16 AM
Reverse gear doesn't shift aqirjazi W202 C36 AMG, C43 AMG 4 10-24-2009 05:16 AM
Reverse gear doesn't shift aqirjazi W202 C-Class 1 10-07-2009 02:43 AM
Transmission-CEL, gears wont shift jchumba W210 E-Class 23 10-27-2008 04:57 PM
Transmission - Reverse only, no FWD gears Benzo5 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-17-2006 12:11 PM
