1997 C280 Rear Brake Pad replacement question? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 11-18-2011, 01:15 PM Thread Starter
Date registered: Jan 2011
Quoted: 2 Post(s)
Almost time to order a rear brake pad set for my 1997 C280.I see it could be a two pin retaining or maybe one retaining pin? Anyone know for sure before i order the wrong set?
Thanks, Troy.....
TroyW is offline
post #2 of 8 (permalink) Old 11-18-2011, 03:44 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Thanks, Troy.....
Easiest thing to do is pop a rear wheel and take a look. If you have smaller hands and good manual dexterity you can lay on the ground and reach in and feel it as well.
Check Codes is offline
post #3 of 8 (permalink) Old 11-20-2011, 09:23 PM
Date registered: Feb 2010
Vehicle: 1997 C280
My 1997 C280 is 1 pin. Just changed the brakes last week.
vette4lyfe is offline
post #4 of 8 (permalink) Old 11-26-2011, 08:15 PM
Date registered: Feb 2009
Vehicle: 1997 c280
mine is a 1997 c280 and it was the 2 pin, so obviously they made a change sometime in the year. so you better check as i bought the wrong ones
sodaman is offline
post #5 of 8 (permalink) Old 11-28-2011, 11:54 PM
Vehicle: 1997 C280
Very weird. Would MB do that? and at that point is it just to mess with us?
post #6 of 8 (permalink) Old 11-29-2011, 12:52 AM
Quoted: 35 Post(s)
It's the caliper design. Every manufacturer does this, either making changes part way through a model run or using a different design in a different facility.
In the time you've spent posting and pondering, you could have checked and ordered the darn things...
post #7 of 8 (permalink) Old 11-29-2011, 01:25 AM
Date registered: Jun 2010
Vehicle: 96 C280 SPORT
If ur not sure either A. Take off the old ones and take it with u when u buy em. Or B. Call the dealer with ur vin# and ask them
chimchongdlight is offline
post #8 of 8 (permalink) Old 11-29-2011, 02:47 AM
Quoted: 35 Post(s)
All he needs to do is pull a wheel and look; why would you remove the old pads and leave the car disabled?
The pin count is (supposedly) tied to the chassis number, but there are plenty of examples where the chassis number says one thing and the calipers say something different. It's the same issue with the 210 chassis. And I'm one of those guys whose chassis number says one thing, so if I buy pads based on my chassis number, I'll end up with pads that don't fit my car.
Hence the suggestion to spend a few minutes confirming EXACTLY what is actually on the car.
If for some rational reason you don't want to do that, buy both, then return the ones you don't need.
Good luck.
    1997 C280 Fuel Level Sensor replacement photog3740 W202 C-Class 15 02-26-2014 03:26 PM
    1997 c280 rear diff fluid swap/clicking in rear. RestoMan77 W202 C-Class 6 11-23-2011 10:51 AM
    w202 1997 c280 LED third brake light thegame11 W202 C-Class 2 08-25-2011 07:18 AM
    1997 C280 rear axle seal question!?! TroyW W202 C-Class 2 01-21-2011 03:49 PM
    1997 C280 fuel level sensor replacement photog3740 W202 C-Class 0 06-18-2007 04:06 PM
