421 Code+ = Pulse module? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-27-2011, 06:53 PM Thread Starter
Date registered: Sep 2010
Vehicle: 1999 c280 base
Exclamation 421 Code+ = Pulse module?
Have a 99 c280 and having problem with the engine cooling fan. Always comes on when you start the car-even on cool days and without the air on.
Car is not overheating. Came up with a 421 code -pulse module. What/where is the pulse module and does this year have a fan relay? Thanks for your help anyone-much appreciated.
cnj280 is offline
post #2 of 6 (permalink) Old 06-27-2011, 07:28 PM
bmeister's Avatar
Date registered: Oct 2007
Vehicle: 1998 c230 170K
Quoted: 9 Post(s)
There should be a module underneath the driver's side fender well. I posted some pics. of what it should look like recently on another posting concerning a similiar issue. Will post again if needed.
Yes, there is a relay/fuse but it sounds like there is a malfunction whether it be the module itself or a corrosion issue. Good on you for posting codes.
There is also especially on earlier models a ballast resistor. We are talking electric and not clutch fan here right? B
bmeister is offline
post #3 of 6 (permalink) Old 06-28-2011, 05:51 PM Thread Starter
Thanks for the reply. Yes, we are talking about the electric fan. Would you mind giving me the thread to the post and the pics-would be great! Forgot to mention that the fan does go off when you shut the car off. Also, want to get new shocks so which are better - Sachs or Bilstein?
cnj280 is offline
post #4 of 6 (permalink) Old 06-28-2011, 08:08 PM
bmeister's Avatar
Quoted: 9 Post(s)
Fan Fun
I bought the biltsteins a few years ago, quite happy with them, a bit more stiff than the original type. I have not had Sach so don't know, some people prefer one over the other.
Would try to clean the connections with electrical contact cleaner.
The black module is similiar to the one on my car the silver colored one is the one you may have. B
bmeister is offline
post #5 of 6 (permalink) Old 09-13-2016, 06:40 AM
kmc
Date registered: Sep 2016
I can not view the images you last attached . I also have the code 421 pulse module . Can you lost the link to the other post with this information . Thanks
kmc is offline
post #6 of 6 (permalink) Old 09-13-2016, 06:58 AM
kmc
Nevermind it was the browser i was using i can see them now . Thank u
kmc is offline
    Error code P0410, air blower and emissions module box hhornis W210 E-Class 3 09-24-2011 08:28 PM
    DTC code 17 on DI module ? Brian McL R129 SL-Class 4 12-03-2009 07:17 PM
    Who has the answer?? B1421 Pulse module (N05) Rumserl C208/A208 CLK-Class 0 07-28-2009 08:27 PM
    95 E320 Code 11, N4/1 module question. tomjode W124 E,CE,D,TD Class 0 09-11-2005 10:23 PM
    Fault: Pulse Module (N65) Ivarx Audio & Telematics Forum 2 08-24-2005 11:24 PM
