Battery disconnect and reconnect help? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-11-2011, 03:04 AM Thread Starter
A1EK's Avatar
Date registered: Sep 2005
Vehicle: W208 CLK230K 2000 year, Past -W203 C Class, W202 C Class, W210 E Class, W201 190E
Quoted: 17 Post(s)
Hi Guys,
I had to disconnect the battery on my wifes 1996 C Class W202 the other day for 5 mins. When I reconnected the battery the car would not idle properely and I had to keep my foot on the gas for a while until it settled. It has got better now its been driven, but it still requires a bit of revving first thing in the morning before it will idle sometimes.
Is there a start up procedure to follow on this model? (I have a CLK and there is a series of tasks I have to do in order to to sync the car back again)
Thanks
18x235x40 (8.5J) & 18x255x35 (9.5J) Brabus Monoblocks VI reps, Eibach Pro lowering kit, no#1 pad front & rear, Rolled arches,20mm rear spacers/15mm front, Flat emblem, Kompressor skirt badges, Parking sensors, Colour coded grill, Front flat lip, Front eccentric camber bolts, Denso Irridium plugs, K&N filter, Sony ICE adapted to steering wheel buttons, Blue LED modified dash & interior.
][/B]
A1EK is offline
post #2 of 2 (permalink) Old 01-11-2011, 04:18 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
I have disconnected my battery without the issues you describe so I doubt they are normal. In my experience, you should only need to re-sync the windows and sunroof after a battery disconnect. Have you tried it again, this time tap the brakes a few times to fully discharge and then reconnect and see if it's fixed?
-Marrs
The Coupe Group on Facebook
DirectLA is offline
    Battery disconnect reconnect reset procedures JonzBenz W202 C-Class 4 07-09-2010 01:56 AM
    W210, Battery Reconnect, Radio Code Entered Then No Volume Pitts Audio & Telematics Forum 2 11-29-2009 10:12 AM
    What happens if I disconnect the battery? roadrutz W164 M-Class 4 10-07-2009 04:53 PM
    Battery disconnect or not? Corkscrew R230 SL-Class 10 02-10-2006 02:54 PM
    Battery Disconnect harb W210 E-Class 11 12-14-2004 01:36 AM
