Possible alarm/immobiliser problem??? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-25-2010, 07:20 PM Thread Starter
Date registered: Oct 2010
Hello,
I have a 1996 C220 with what I believe is an immobiliser problem.
First off, I had a problem with turning the key (blade key) so I used brute force to get
it to turn. After that sometimes it turned just fine and other times I had to force it again.
That was a year ago. Now all of a sudden the car will not
start. I can turn the key so that all of the lights (and everything electrical) can turn
on but when I turn it all the way nothing happens at all. The red and green lights on the
review mirror flash alternately.
Note: The gas gauge has not been working properly for a couple of months. Sometimes it shows
empty and sometimes it shows the correct amount of gas.
Things I have tried
I have tried locking and unlocking the doors with the button on the fob as well as
manually through the driver's door and trunk. When I use the key fob everything looks
normal as far as the system appearing to arm itself (red flashing light for lock, green
for unlock). I have tried to "reset" the system (holding down "O" button and turning the key etc), though I don't think I did it correctly.
I have unhooked the battery for 20 mins. Nothing has worked.
I even removed the foot plate from the passenger side footwell and removed all the
units that I believed were part of the immobiliser. I have put them back in.
The short of it is, I have spent days researching an answer and I have tried many
different suggestions. I've now reached a point where I've tried so many things
that I don't even remember what I've done. I paid a visit to a mercedes dealership
and their answer was "we are not quite sure what the problem is".
So now I'm a little bit confused and frustrated and don't know what to do next.
Any help would be greatly appreciated.
Thanks,
Jay
PS: I'm sorry for the long post but I just didn't want to risk leaving out
any details that may be helpful.
juseasy is offline
post #2 of 4 (permalink) Old 10-27-2010, 01:29 AM
Vehicle: 300CE-24, W204 C220 CDI, W210 E55 AMG, W124 300TE, W163 ML270 CDI
Send a message via MSN to Mcmerc01
So when you have the Key in the ignition, and turn it to position 3, the car doesn't crank? Do you just get an emptyness? or does it turn to that position but receive no response from the car.
It might be the immobiliser, or the ignition barrel. Similar thing happened to me, changed the Battery on the car and it worked fine. Then again, You say you had to use brute force to turn the key, what you experience there is I believe the steering lock. Make sure the car is in park, and as your turning the steering wheel, crank it. That usually works.
So this may point to the immobiliser yet again.
Someone more experienced may have to correct me here
Mcmerc01 is offline
post #3 of 4 (permalink) Old 11-05-2010, 06:39 PM Thread Starter
Hi Mcmerc01
Thanks for your reply. Sorry I read this so late. My computer crashed on me (arrrgghhh what else can go wrong!).
When I turn to position 3 I get no response from the car. I also forgot to mention that the battery was replaced about 4 months ago. I have tried to start the car while turning the wheel but same result.
I really hope it's not the ignition barrel....I was hoping that if it was an immobiliser problem I could perhaps bypass the immobiliser.
juseasy is offline
post #4 of 4 (permalink) Old 11-07-2010, 02:56 AM
Originally Posted by juseasy View Post
Hi Mcmerc01
See, the thing is, the immobiliser is not a common problem, and if it were, bypassing it is not a good idea. Its best that you repair it. Try changing the barrel, this isn't such a bad thing, in fact its not too expensive to change the barrel itself since its only the barrel, not the entire ignition section. (do you get me?) I'm in Australia, including labor it cost me $170. Far cheaper than repairing the immobiliser I think. Then again, change the barrel; ergo new keys and hopefully that fixes the problem. Just let the mechanic take a look at it, or if your quite the handyman, go to a wrecker, locate an ignition barrel with the keys and swap them over. Its far cheaper this way but and there is a but
Make sure there are keys, try and buy from an honest man (remember there are two keys)
Disconnect the battery before performing the swap
There's a tutorial here I believe that takes you step by step on how to change the ignition barrel.
Hope I helped
Mcmerc01 is offline
    1995 c220 immobiliser problem jamesybutler W202 C-Class 11 04-22-2011 01:22 PM
    Alarm Problem sszakats G-Class 1 04-08-2010 07:37 PM
    Serpi alarm immobiliser matola W124 E,CE,D,TD Class 0 01-19-2008 11:35 AM
    ALARM/IMMOBILISER Valmark Audio & Telematics Forum 1 05-11-2005 02:34 PM
    Alarm Problem Gta255 W124 E,CE,D,TD Class 0 10-27-2004 01:16 PM
