Engine misfiring? Does a popping sound mean misfire? - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 05-24-2010, 02:01 AM Thread Starter
MB-W202's Avatar
Date registered: May 2010
Vehicle: 1995 C280 150K miles
Quoted: 89 Post(s)
The popping sound in question occurs almost instantly as I press my gas pedal to accelerate.
Scenario: This popping sound occurs when I have suddenly accelerated from a stop or especially after braking to slow down and depressing my gas pedal to accelerate back up. A few milliseconds after pressing my gas pedal, I hear a popping sound closer to the center firewall of the engine. I seem to feel the pop on my pedal as well, like something came loose!
Sometimes the car hesitates for half a second and then picks up and goes as nothing happened. Other times it hesitates further and I have to let the pedal completely off and then gently accelerate and the car recovers and goes as nothing happened.
This doesn't happen often time and is very hard to duplicate. But does happen. I have never had a check engine light come after the event. My gas pedal linkage is fine and there are no binds anywhere.
Is this a misfire? If this is a misfire shouldn't the car continue hesitating or misfiring more often?
I changed my spark plugs with Bosch F8DC4 plugs 25K miles ago.
Your analysis is appreciated.
MB-W202 is offline
post #2 of 19 (permalink) Old 05-24-2010, 08:45 PM
bmeister's Avatar
Date registered: Oct 2007
Vehicle: 1998 c230 170K
Quoted: 9 Post(s)
I would check your coils for cracks and the plugs from what you said. Your year may be subject to wiring harness issues as well. A cleaning of the throttle body may help.
The EGR tube is suspect to carbon build-up that may contribute to what issues your having too. B
bmeister is offline
post #3 of 19 (permalink) Old 05-24-2010, 09:34 PM Thread Starter
MB-W202's Avatar
Quoted: 89 Post(s)
Thank you. My model year is subject to wiring harness failures. Strangely enough part of my wiring harness seems like it was replaced and there are parts of it fraying. I'll check the ones close to the coils and plugs.
Btw, is it possible the previous owner replaced only parts of the wiring harness??
How far in do I clean the throttle body? I can easily clean the end tip of it with WD40.
The EGR usually don't go bad but your point on carbon buildup is something I didn't think of. How far do you clean? The little tube that runs to the vacuum lines?
Thanks
MB-W202 is offline
post #4 of 19 (permalink) Old 05-25-2010, 12:28 AM
bmeister's Avatar
Quoted: 9 Post(s)
Yea. its possible the previous owner did some repairs (damage control) to specific parts of the wiring they found to be crackly crunchy, if it was the rest probably is/was not far behind. If I am not mistaken doin12volt can repair the harness for you if need be. Also the connector to the throttle body can get the same way, uhgg! Usually for a proper throttle body cleaning it should come off so you can do a decent job, there are several write ups on that.
The EGR tube can be wire wipped (wire attached to end of drill) with a drill but again the best solution is to remove so you can operate on the tube easier. B
bmeister is offline
post #5 of 19 (permalink) Old 05-28-2010, 11:39 AM
MorbidBarbie's Avatar
Date registered: Mar 2010
Vehicle: 1995 Polar White C280 (79,000 miles)
My car was doing that until I took it in.
I ended up needing new spark plugs, and I had an oil leak. My engine was misfiring because of all of this.
Maybe you have a a bad spark plug?
MorbidBarbie is offline
post #6 of 19 (permalink) Old 05-28-2010, 03:09 PM Thread Starter
MB-W202's Avatar
Quoted: 89 Post(s)
Barbie, you most likely are right. I changed my plugs 2 years ago. Maybe it is time again.
Did your popping issue completely go away after the spark plug change?
MB-W202 is offline
post #7 of 19 (permalink) Old 05-28-2010, 03:24 PM
misfire
I would change your air mass meter or also known as m.a.f sensor. when these go wrong you can get lack of power, bad throttle response and a feeling of a misfire.They dont always throw a fault code up either as it always gives out a voltage but the wrong one! This would be the first thing i would change from experience. Just make sure it is a genuine part & not aftermarket as these tend not to work.
jedwell77 is offline
post #8 of 19 (permalink) Old 05-28-2010, 03:57 PM Thread Starter
MB-W202's Avatar
Quoted: 89 Post(s)
the repair adds up. i can do most of these myself so it will only be parts. the coils, plugs, maf and ultimately the damn harness. maybe it is time to sell the car! naaa i love the car.
MB-W202 is offline
post #9 of 19 (permalink) Old 05-28-2010, 03:57 PM
It's been fixed for about 3 weeks now, and no more sounds.
One particular occasion, I was turning sharply around a corner and then slammed on the gas. I heard the noise... once I was on the freeway it ran fine, and no noises. It was just during times of rapid acceleration.
post #10 of 19 (permalink) Old 05-28-2010, 04:20 PM Thread Starter
MB-W202's Avatar
Quoted: 89 Post(s)
Spirited driving Barbie... So it is you who was blasting past me the other day.
MB-W202 is offline
    Popping sound subwoofer in HK sound syste, Hsheikh W211 E-Class 5 04-30-2010 12:52 PM
    Engine reving itself and popping sound from rear azar87 W210 E-Class 7 04-30-2010 07:26 AM
    popping sound from firewall wbrokow1 W163 M-Class 4 09-16-2008 06:34 PM
    Driver's seat "popping " sound lwain56 W220 S-Class 2 01-22-2006 11:07 AM
    Popping sound from MCS? LA Swede W163 M-Class 0 08-08-2003 10:31 AM
