Testing Ignition Coils?? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-19-2010, 04:49 PM Thread Starter
Date registered: Dec 2008
Vehicle: 1995 C280
Send a message via AIM to Zak62592
I've probably addressed this issue before, but I want to get to the source of the misfiring, and check my ignition coils. How do I access them? I'm assuming they're under the spark plug engine cover thing. How do I test each one of them? So I don't go about replacing all three? Thanks!
Zak62592 is offline
post #2 of 8 (permalink) Old 05-20-2010, 02:49 AM
panzerbenzer's Avatar
Vehicle: 1989 560 EUROSEL 1984 190e8V 2000 e320 sport
Send a message via Yahoo to panzerbenzer
youll need at least one new one then swap each out individually with the new one it may seem like alot of work to replace one at a time though, so replace the first put back together run it, do the second replace , thn the third
YOU CAN RUN BUT YOULL ONLY DIE...TIRED!!If you insist on driving blind and deaf to the obvious warnings coming from under your Mercedes' hood, the next sound you hear may be a rapping or knock noise from the rod bearings - which will eventually be followed by dead silence as your engine seizes and your Mercedes coasts to a dead stop.LOL
panzerbenzer is offline
post #3 of 8 (permalink) Old 05-20-2010, 06:49 AM
Date registered: Feb 2009
Vehicle: 1997 c280
i have all 3 oem ignition coils for 1997 c280. thought that was the problem so replaced them all. the problem ended up being the maf and fuel filter. so i have 3 for 50 bucks plus shipping if your interested let me know.
sodaman is offline
post #4 of 8 (permalink) Old 05-23-2010, 10:14 AM Thread Starter
Vehicle: 1995 C280
I'm guessing these black things are the ignition coils?
Also the circled wire is the one that connects it?
ID:	309772   Click image for larger version
Zak62592 is offline
post #5 of 8 (permalink) Old 05-23-2010, 10:32 AM
Vehicle: 1997 c280
im not sure what your question is. the ignition coils are the 3 items you have circled that have metal going around them. if you unplug both wires going to it, you lift them up off the spark plug. It is covering the spark plug. the other wire with question mark is just and ignition wire(spark plug wire). so you will have one igniton coil firing for two plugs, thats why you only have three and are feeding the other 3. the way the wires plug up is on top of your engine cover. so dont worry about forgetting it shows you. so unplug both sides of the ignition coil. one side is the harness, and one side is to your other spark plug wire. there are ignition wire boots that go on the bottom of the coils to connect to the spark plugs, sometimes these need to be replaced as well. good luck
sodaman is offline
post #6 of 8 (permalink) Old 05-23-2010, 10:54 AM Thread Starter
Vehicle: 1995 C280
What was your car doing that made you think that you had to replace them?
Zak62592 is offline
post #7 of 8 (permalink) Old 05-23-2010, 11:03 AM Thread Starter
Vehicle: 1995 C280
Alright I just needed to know if I was looking at the right thing or not, thanks!
Zak62592 is offline
post #8 of 8 (permalink) Old 05-23-2010, 11:19 AM
Vehicle: 1997 c280
my issue was come to a stop and it might start idling funny, and then when taking off it would bog down until it started going. so it felt like it was falling on its face. I had already replaced both o2 sensors, camshaft sensor, then i crank sensor, then ignition coils. I knew that it needed for maintenance anyway so i didnt mind replacing stuff. I just got it on ebay for good cheap prices on oem equipment. but then i checked the fuel filter and found dry rotted lines leaking, and i replaced the fuel filter. it ran better but didnt fix the problem. i put in an air filter and the dieing stopped, but the check engine remained. which was the maf sensor code, and i had replaced it already with a cheap one, so i went out and bought the bosch and it was finally all fixed. the 02 sensors and cam sensor i had replaced earlier in the year when i got o2 sensor codes. seeems like all along it was probably the tune up stuff and maf sensor. good luck
sodaman is offline
testing ignition coils strutsekake W126 S,SE,SEC,SEL,SD,SDL Class 2 09-30-2009 07:10 PM
Ignition coils samosali W140 S-Class 11 08-24-2009 02:59 PM
need to borrow coils in So. Cal. for testing silverslk R170 SLK-Class 9 02-17-2008 05:45 PM
Ignition coils sanmanbx3 W163 M-Class 1 05-01-2006 07:13 PM
Ignition Coils Phil G-Class 2 11-28-2005 06:24 PM
