Checked the oil the other day and noticed the dip stick is starting to rust near the top of the stick. What would cause this and has anyone else discovered this? I did replace the o-ring on the dip stick at last oil change about 2K miles ago as it always felt loose. Is the dip stick suppose to be loose to vent?
The O ring should be a good seal or will cause engine to run slightly rough.
Your rust is probably caused by short runs in cool weather generating combustion moisture - this will burn off on a longer trip (and possibly give the impression of oil usage)
I get it in 25degC weather when doing 7 min trips during the week
That sounds right as my daughter uses it mostly for short trips to school and back and the car dosn't get hot enough to get the oil hot. The car dosn't use any oil and it dosn't have any signs of a head gasket leak, so this seems to be the only logical explanation.
can I still drive the car if I see rust on the dipstick tip where it touches the oil?
I'm concerned that this rust, that feels like sand, can damage the engine if it gets into the oil.
Please advise.
Can I still drive the car if I see rust on the dipstick tip where it touches the oil?
Please advise.
Clean the rust off the end of the dipstick and then check the oil to see if it's clean.
Check your coolant level, and look for any oil contamination in your anti-freeze.
When was the car last started/driven?
Outside or in a garage?
Last oil change?
rust is more powdery. if there is rust or sandy particles in the oil that is sticking to the stick you need to change the oil and filter. those particles should have been caught in the filter. better yet send the oil for analysis.
When time comes for oil change keep the old oil filter and check it if you are concerned about the engine , oil filter tells alot about the engine health , watch this video on youtube for how to check the oil filter :
https://youtu.be/NwVGHdZTA58
