Instrument Cluster issue W202 1997 C230 - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 03-02-2010, 08:30 PM Thread Starter
Date registered: Jan 2010
Vehicle: 2002 Black E320 (previously 560SEL, 380SE, and 300SD)
Hello, I'm new to the forum. My g/f's C230 had the charge light come on. The car went into a low idle and the tach, speedo, ambient temp, fuel, temp, and oil gauge went to maximum. Ambient temp reads 137F.
I replaced the battery(> 7 years old) and the alternator. Battery charge light is gone.
My mechanic(I own a w210) told me to bring it in and he would reset the computer. This did not work. the car has many miles, so I decided to troubleshoot myself to save her money.
I have read that bad alternators can mess up the cluster b/c of failed capacitors.
I have also found a site, which informs me that the signals for the tach, speedo, temp, and oil come from the N3/7, N3/10, N3/11, and N3/12 engine control modules.
Where are these located? Is there fuse or relay protection? I have checked fuses and all appear to be fine.
Any help would be appreciated.
Thank you for your help.
Karl
kdoubleu is offline
post #2 of 11 (permalink) Old 03-02-2010, 08:38 PM Thread Starter
Interesting w202 Site. Please help on above request!
Some interesting information on the w202 C Class:
Default
kdoubleu is offline
post #3 of 11 (permalink) Old 03-02-2010, 11:00 PM
xvvvz's Avatar
Date registered: Sep 2006
Vehicle: '99 2.3L Kompressor
Nice find! Someone has posted the CD that MB sells to consumers for $120. The best sub section is the disassembly section. There are some great videos there. Make sure to look for red links in the upper right corner of each page that will take you to more detailed information on a topic and where many of the videos are buried.
xvvvz is offline
post #4 of 11 (permalink) Old 03-02-2010, 11:01 PM
xvvvz's Avatar
Have you checked out the K40 k-40 relay? If not, do a search in this forum for posts on this. Some of the relays are underneath the fuses in the front fuse box.
xvvvz is offline
post #5 of 11 (permalink) Old 03-02-2010, 11:08 PM Thread Starter
Thank You
I will check K40 on the forum and check functionality on the car. Any hint as for location? I'm trying to get a repair manual or schematics.
Thank You for your help!
kdoubleu is offline
post #6 of 11 (permalink) Old 03-03-2010, 10:23 AM Thread Starter
Picture of the Cluster Issue for more information
Attached is a picture of the instrument cluster "issue". This occurred when the battery charge light came on. The car went into idle even with gas pedal depressed.
After battery and alternator replacement, the battery charge light went away. Fuses were checked, but nothing was found. The mechanic tried to reset the computer, but found nothing.
The car runs fine. Everything works, but what is seen in the picture.
Couple of questions:
1. Where is relay K40?
2. Where are N3/7, N3/10, N3/11?
3. Is a relay or fuse associated with N3/7, N3/10, N3/11?
4. I have heard people have used the AC unit for diagnostics, any information or instructions?
5. If I were to pick up a used working cluster, would it need to be reprogrammed?
6. Does anyone have the wiring schematic for the cluster to the ecm?
Thank you for your help(in advance)
Karl
kdoubleu is offline
post #7 of 11 (permalink) Old 04-08-2010, 09:06 AM Thread Starter
Okay back and need more help
I have narrowed it down to the cluster. Does anyone know what year clusters will work for a 1997? It seems ebay has all, but 1997.
kdoubleu is offline
post #8 of 11 (permalink) Old 04-13-2010, 08:53 AM
Date registered: Jun 2007
Had my gauge cluster repaired by these guys. Fast turn around and good customer service. Happy with the results.
BBA reman. ABS, ecu's, throttle bodies, air mass meters, and catalytic converters
Cost was $225
carmad is offline
post #9 of 11 (permalink) Old 04-13-2010, 09:19 AM Thread Starter
Fixed
Thank you for your help. I pulled a 1997 cluster from a Mercedes wrecking yard and it worked without issue. It did have a different part number, but it was still compatible. The mileage counter is off. Our car had 194K and the wrecking yard car had 86K. We will keep the car till it dies, so it isn't too big of a deal. Paid $150 for the cluster.... I hear to correct the odometer it is another $150. I will live without the correct mileage...
kdoubleu is offline
post #10 of 11 (permalink) Old 10-25-2013, 01:33 PM
Date registered: Oct 2013
Vehicle: 1997 C230
Instrument cluster dials dead
I see that one of you sent it to BBA Reman to get repaired. Will the car still function if I take out the cluster and send it in to get repaired or will I be without a car until I get it back?
Thanks,
Brian
bsilvers is offline
    W202 Instrument Cluster Failure Lou W W202 C-Class 18 09-21-2012 07:13 AM
    Help with 1997 500sl Instrument Cluster cigator R129 SL-Class 9 12-15-2010 04:49 PM
    W202 C230 K Instrument cluster Kobus Coertzen W202 C-Class 4 06-17-2010 03:13 PM
    FS: W210 1997,98,99 Instrument Cluster leeah For Sale/Wanted/Trade/Giveaway 0 01-27-2007 06:48 AM
    W202 Instrument Cluster duanedewitt W202 C-Class 4 09-07-2006 06:43 AM
